  • Dot Guests: 390
Author Topic: What size brake booster?  (Read 8996 times)
« on: November 08, 2012, 10:17:48 PM »
Hi Guys
I'm in the process of changing the brakes on my van and at the same time I will be upgrading the master cylinder.
To make upgrading the master cylinder easier, I plan to also change the booster.  The Ford XA/XB master should work well for the brakes I am using.
During my research I have found a booster that will bolt to the Bedford firewall and except the falcon booster with no mods/filing etc at all. My only concern though is the booster I have found is pretty small. Its 180mm dia.
Anyone have a clue about booster sizes and their effectiveness? The particular booster I have found is available in single and dual diaphram in the same dia.
Re: What size brake booster?
« Reply #1 on: November 09, 2012, 06:06:25 AM »
It doesn't really matter what size you use - example; think of HQ holden (big booster) now think of titan/dyna etc truck (small under dash booster)
even compare things like escort and hq or torana and hq
The booster is a vacumm, it can only vac so much whether duel or single and the valve (pvc vavle) stops bleed back. The more important thing is master cly type/size; ideally you need to have big enough size to feed the wheel clyinders and of proper type disc/drum or disc/disc although you can use drum/drum master if you are running disc/drum setup (ie bedford booster and master with hq discs on front) with or without a proportioning valve.
Probably a better example would be hot rods, a lot of hot rods place the booster under the floor to keep a clean engine bay, they use a small truck type booster (the titan/dyna etc style) and as we know these rods can be from 100 to 1000+ horsepower running alsorts of suspension and brakes
« Reply #2 on: November 09, 2012, 09:05:51 AM »
Thats good to know. I'll try this one out and see how it goes. I'm just happy it bolts in with no mods.
Offline Vandee
« Reply #3 on: November 09, 2012, 09:34:19 AM »
If you don't mind me asking, what is the set up from that bolts straight in. Thanks
« Reply #4 on: November 09, 2012, 10:03:02 AM »
Once I know it works I'll be sure to share. I have a few of these boosters here to sell if they work. Much cheaper than LJ booster to.
Offline Vandee
« Reply #5 on: November 09, 2012, 12:19:50 PM »
Ok, Thanks
« Reply #6 on: November 09, 2012, 06:13:33 PM »
I'm running a commodore booster for the v6 standard van and using toyota booster for the v8 in the custom
« Reply #7 on: November 10, 2012, 09:14:38 AM »
L300 is a nother popular one for customs, it goes under the dash leaving that smooth look under the bonnet ::)
Offline tiwaz_nz
« Reply #8 on: November 10, 2012, 07:00:42 PM »
i like the idea of the l300 under the dash .. but wasnt sure of the size as they look small
the new shape hiace has a small setup in tghe front bonnet area .. less room than a bedford
« Reply #9 on: November 11, 2012, 09:35:40 AM »
a mate used the L300 on a fc holden, running a tuff 327, with 4 wheel disc's. He pulls up great. He also uses a vacum cannister, but thats due to the size of the cam in it
