  • Dot Guests: 184
  • Dot Users: 1
  • Dot Users Online:
Author Topic: Axle lengths  (Read 11601 times)
Offline Vandee
Re: Axle lengths
« Reply #10 on: November 06, 2012, 08:06:43 AM »
OK, they are both the same length, just fitted them back in the diff and I am able to change sides around, in the old days, we used to carry only one spare and even remember changing them once, will post lengths if required.
Offline JohnnyJ
Re: Axle lengths
« Reply #11 on: November 06, 2012, 10:48:01 AM »
Are they 825mm from the back of the hub?
Thank you for your trouble.
Offline Vandee
Re: Axle lengths
« Reply #12 on: November 06, 2012, 02:15:20 PM »
I get 834, that is from the (Hub)? part that the suds fit into, photos attached. This is for the 10" drum, 21 spine axle.
« Last Edit: November 06, 2012, 02:17:25 PM by Vandee »
Offline JohnnyJ
Re: Axle lengths
« Reply #13 on: November 06, 2012, 05:30:58 PM »
Thanks Vandee, That is them.
Re: Axle lengths
« Reply #14 on: November 06, 2012, 08:11:34 PM »
is the distance from the end of the splines to the top of the axle different on the pass side eg longer than the drivers side , just something i seem to remember maybe commenting on  when mouse n i tackled my diff in melb.... could be irrelevant  ??? ( or thinking bout it now,could be cos it chewed the end of the splines out when the axle slid out the bearing n diff round that roundabout in eltham  ;D  ;D  ;D  ;) )
Offline Vandee
Re: Axle lengths
« Reply #15 on: November 07, 2012, 01:00:38 PM »
No, they are identical no matter where you messure from, bearing / collar etc. Have just put the diff back together and swaped axles around, as I had marked them when I took them out, all fits and works well diff back in mates van today, no problems. Other diffes / 12 bolt etc have different size axles as the diff housing sits off centered if I remember right, but Bedford diff's are centered, this is the easy way to tell if they run different size axles.
« Last Edit: November 07, 2012, 01:07:45 PM by Vandee »
Offline JohnnyJ
Re: Axle lengths
« Reply #16 on: November 07, 2012, 07:06:21 PM »
Thanks again Vandee.
