  • Dot Guests: 46
Author Topic: 253 v8 into bedy  (Read 12624 times)
Re: 253 v8 into bedy
« Reply #20 on: February 04, 2013, 04:52:31 AM »
The driveshaft is no good anyway, as I understand it is from a LWB and if it is going into a SWB it,s the wrong length anyway, but as you said this is no big deal to put right. I would swap front ends and enterchange the best parts, will need to use the whole Hub or disk with arms etc as there is a difference in size.
Offline tiwaz_nz
« Reply #21 on: February 04, 2013, 02:33:21 PM »
the drive shaft is a two piece on the lwb .. will be getting the ends put on to the swb shaft
the 10 bolt rear is to be swaped soon needs a small mod (lwb has shocks on inside of rail ,swb is on outside)
not sure if thats a lwb/swb thing or and age thing
i thing swaping the front end over will be best as its running hq disks
Offline greasey monkey
« Reply #22 on: February 04, 2013, 03:18:37 PM »
can you use the 202 engine mounts for a 350 ??
i ask this as i have a 202 in my 79 van and a 350 in my 73 parts van
i was planing to just roll one out and the other in but if its mounts up should i use the newer cross member ?
i saw a add on trade me that made me think ...
http://www.trademe.co.nz/motors/used-cars/holden/cf/auction-557905617.htm
""the front end has the hq disc brakes and is set up for a 350 chev but has a 202 holden in it at the moment have drive shafts for her the rear diff is an old bedford diff just so it can be moved "" ???
why this has a 202 in it instead of the 355 its used run back in the day was due to the previous owner gutted it of the drive train and the new owner (wraithknight on here) all he could get his hands on at the time for a power plant for it was a 202 not sure how he has mounted it up but i can try to find out
Scott
Offline tiwaz_nz
« Reply #23 on: February 04, 2013, 03:37:05 PM »
please ... would be good to know how hes done it ...
scott are you coming up to wellington at easter ?
« Reply #24 on: February 04, 2013, 04:02:06 PM »
will see what info i can get out of him for you on his mounts.
yes am hoping to attended Nats in wellington - all going to plan i hopefully will be driving my van up for it
Scott
Offline tiwaz_nz
« Reply #25 on: February 04, 2013, 04:08:51 PM »
fingers crossed all goes well and will see you there in your van :)
Offline cfjeff
« Reply #26 on: February 04, 2013, 05:57:28 PM »
scott you got the broken sduds out yet? and the exhaust manifold fitted? Sorry didnt make it over on the weekend, may be able to give you a few hours on maori have a moan day on wednesday if you like, maybe get electrics finished?
Cheers Jeff
Just customize it!
« Reply #27 on: February 05, 2013, 05:08:17 PM »
Cheers Jeff
heya Jeff
all good mate, had to work on saturday n spent sunday trying to get the dash finished off, no luck on the studs as yet as i didnt get the right size easy out so it'll be another trip to mitre 10 for a couple more of them. sounds good if you've got a couple of hours to spare
Scott
Offline cfjeff
« Reply #28 on: February 05, 2013, 05:38:16 PM »
no worries mate will ring ya tomorrow, and we can get some more things crossed off the to do list.
Cheers Jeff
Just customize it!
Offline tiwaz_nz
« Reply #29 on: February 05, 2013, 07:29:58 PM »
cross lots off and drive it up ... want to see the rb conversion  :D
