  • Dot Guests: 392
Poll
Window setup
I like it
6 (40%)
Don't like it
6 (40%)
Other way around
3 (20%)
Total Members Voted: 15
Author Topic: Window setup  (Read 12084 times)
Re: Window setup
« Reply #10 on: September 26, 2012, 01:37:09 PM »
Ok thanks guys for the window vote, I would go windowless, but I have a wife and a kid, so If I want them in the van or to use it over the family wagon, I must have seating and the window view for those seats. ???
Re: Window setup
« Reply #11 on: September 26, 2012, 02:33:27 PM »
i like little window at front n big one in the back, im 1 of the 2%, lol.
Re: Window setup
« Reply #12 on: September 26, 2012, 06:32:55 PM »
Ok, I'm thinking bay at the back, its not as big as Garrys on his bedford, it's about 650x500 and a smaller window up front, the ones I have are 600 long x 400 wide, so they will fit in the rebate.
Re: Window setup
« Reply #13 on: September 26, 2012, 07:44:09 PM »
Why not put a cargo door with whatever window you want in and keep your door as is then you can have a windowless van or with half an hrs work you can convert it into a family van
That is what I have done 2 doors 2 looks
Offline tiwaz_nz
Re: Window setup
« Reply #14 on: September 27, 2012, 04:42:37 PM »
im planing on paneling in my back windows .. what thickness sheet should i get ?
Re: Window setup
« Reply #15 on: September 27, 2012, 06:07:38 PM »
20 gauge
Re: Window setup
« Reply #16 on: September 28, 2012, 12:06:54 AM »
keep it windowless, and utilise a custom bench seat for the front, I'll knock one up if you like. Unfortunately thats why i cut bigger windows in mine HUGE  regrets!
« Last Edit: September 28, 2012, 12:09:15 AM by Dano »
Re: Window setup
« Reply #17 on: September 28, 2012, 06:31:24 AM »
Thanks Dano, but in NZ >:( besides that, I have the v6 in it and not much foot room in front of the engine cover so a 3rd seat is out....... but know what you mean about windowless, I grew up with these vans around me (below) Ian Knights - Strip Hauler, Roy Bennets? Cosnic Raider and Garry's Windsong, so love the widowless vans, other option is to put the Bay window, that is only 650x500 in the small window rebate behind the cab as it is a Jumbo, won't be inline with the middle seat but will let the light in and would be able to look out it on an angle..... and the rest of the area would remain windowless...
« Last Edit: September 28, 2012, 07:27:29 AM by Bas / NZ »
Re: Window setup
« Reply #18 on: September 28, 2012, 07:27:43 AM »
I think a window is a window until it's recessed, becomes a bay window. Then it's custom
Offline tiwaz_nz
Re: Window setup
« Reply #19 on: September 28, 2012, 02:58:33 PM »
i was thinking about using a electric sunroof that winds down
one on each side would be good for those in the back seats
what is 20 gauge in mill ?
