  • Dot Guests: 245
Poll
Window setup
I like it
6 (40%)
Don't like it
6 (40%)
Other way around
3 (20%)
Total Members Voted: 15
Author Topic: Window setup  (Read 9521 times)
Offline Jeff
Re: Window setup
« Reply #20 on: September 28, 2012, 06:14:28 PM »
From what I have found 20 gauge is a bit of a loose term, but it seems to be almost 1 mm.
Unless you are talking about shot guns, that is.
« Last Edit: September 28, 2012, 06:18:05 PM by Jeff »
Funny old life.
Re: Window setup
« Reply #21 on: September 28, 2012, 07:01:50 PM »
Just ask for 20 GAUGE at the place you get your sheet metal from, if they don't no what you mean, I would get out of there quick........... :D
Re: Window setup
« Reply #22 on: September 28, 2012, 08:10:37 PM »
Hi Guys, what is the best Sealent / Adhesive to use to bond the aluminum framed window to my van, someone suggest Sikaflex MS, anyone got any ideas, Cheers.
« Last Edit: September 28, 2012, 08:12:12 PM by Bas / NZ »
Offline Hobbit
Re: Window setup
« Reply #23 on: September 28, 2012, 11:52:36 PM »
Polyurethane adhesive is used for body building.
Offline Jeff
Re: Window setup
« Reply #24 on: September 29, 2012, 05:32:59 AM »
GALVSEAL ....waterproof and semi-flexable.....In tubes from hardware shops..... The flooring trade uses it for glueing aluminium noseings to concrete stairs.....I have been told that some motorbody repairers use lots of it....and I use it everywhere I need strength in a join. you can even repair leaks in the exhaust with it.
The problem comes when you need to remove something glued with it.
Can be messy to use and is a grey colour, but paintable.
LOL...this is not spam  :D
Funny old life.
Offline Hobbit
Re: Window setup
« Reply #25 on: September 29, 2012, 10:10:20 AM »
Sikaflex is a polyurethane sealant, as the name implies, it remains permanently elastic.
I used Bostic Matrix FC, which is similar...sandable, paintable, flexible and durable.
Comes in black, $20 a cartridge.
Re: Window setup
« Reply #26 on: September 29, 2012, 10:45:36 AM »
Thanks for that, talked to a Motor Home builder here and they said that is what they use, yes it is a sealent but also states it has good adhesive properties, I know Polyurethane Adhesive are used but some people say that it is better to have it flexable when using it on cars / vans etc as it takes the strees off the window, could always make up a bracket system inside to double hold the frame in.........
Re: Window setup
« Reply #27 on: September 29, 2012, 10:46:47 AM »
Yes have used this before as well, but feel this may not be the best product this time around. Cheers
