  • Dot Guests: 44
[Yesterday at 10:28:23 PM]
Author Topic: mechanical to hydraulic clutch  (Read 4562 times)
Offline alice
« on: September 18, 2012, 04:58:23 PM »
hey guys,i recently bought a celica 5speed(i think its w50,the guy i bought from said it was from the 70's,but if someone could confirm that from the photos in my gallery...)
it has a crs bellhousing,spigot bush,crs slave cylinder bracket and some kind of fork?i looked on the crs web site to what else i need:
pivot ball
cable throwout fork?
thrust brearing carrier?
clutch plate
pressure plate
speedo cable
gearbox rubber mount
and its missing the shifter,which i'm aware i need to adjust to fit in the original position.also aware i have to modify the cross member.is that it?
also my clutch is mechanical do i have to convert to hydraulic?
Offline Marky
Re: mechanical to hydraulic clutch
« Reply #1 on: September 18, 2012, 07:09:18 PM »
hi mate
some pics in my gallery of this conversion i did on last CFS
u will need to adapt cross member....celica box is shorter and lower than 3/4 speed holden  boxes..
-tail shaft will have to cut n rebalanced and fitted w Toyota Yoke
-bell housing adapter
will dig up my notes..on what i did to mine..more to come
Creative Media Producer
« Reply #2 on: September 18, 2012, 07:38:41 PM »
The clutch plate there is 2 choises, celica plate gives you a normal clutch and the Toyota Dyna gives you a heavy duty clutch. for the preasure plate just use a holden.
When its a screw on cable on the back of the speedo use Toyota RT104 Corona, (measure first), If thats not long enough use Dyna.
Rear mount, has to be a celica
If the conversion uses a cable fork, means it must of been for a commodore, so just use the fork and bearing and pivot ball from one.
their is a number of different toyota 5 speeds, the main thing is the position the shifter comes up, bend the shifter to suit you. good luck on the relocation
***   DON'T FORGET THE SPIGOT BEARING  ***  this goes in the back of the crank, and supports the main input shaft from the gear box.
Things to get from CRS
  Spigot bearing
  piece to lenghten the tail shaft (best way is to get the shaft made to suit)
« Reply #3 on: September 18, 2012, 07:43:42 PM »
PS if you stay hydraulic, they used a EK holden slave cylinder, HK Holden flexible hose and any early holden master cylinder
Hope that helps
« Reply #4 on: September 19, 2012, 06:58:26 PM »
I was talking to my old partner today and I brought up the 5 speed conversion, he reminded me that the bellhousing were different. Think the pivot ball were on oppste sides. One pulls and the other pushes. might pay to checck
« Reply #5 on: September 20, 2012, 06:06:33 PM »
Ive just removed my supra 5speed and need to change gearboxes this week,will take some photos and rejog the old memory banks for info but wont be home till.next wed.dont use early holden master cylinderas now way too expensive my last hk huge  lasted for.only 6months before it started to weap again.i was told to use xw master and toyota slave .i have felt fhis pedal and was sooo soft i will to change to this set upadventually.dano
Offline alice
« Reply #6 on: September 22, 2012, 08:01:21 AM »
cheers...i always understand things better when i see it for myself,so i'm pulling out my gearbox to see all the holden components.photos help lots too.
