  • Dot Guests: 275
Author Topic: Whats the name of the type of bit needed to remove the door hinges  (Read 3122 times)
Offline atk1
« on: September 12, 2012, 06:34:54 AM »
Hi, Im removing the side & rear doors and I need to find the big bit to unscrew the bolts. I know its almost like a philips but not quite and I know it has its own name. Cheers
Re: Whats the name of the type of bit needed to remove the door hinges
« Reply #1 on: September 12, 2012, 06:54:12 AM »
Are you talking about a 'pozi-drive'?
« Reply #2 on: September 12, 2012, 06:56:17 AM »
it's either number 2 or 4 in the impact driver set
« Reply #3 on: September 12, 2012, 09:39:16 AM »
yep i used an impact driver on mine as well, works a treat.
Offline VanWolf
« Reply #4 on: September 12, 2012, 10:39:59 AM »
Used the same here. Bit of penetrating oil/WB-40 first
Mike
