  • Dot Guests: 294
Author Topic: diffs  (Read 5029 times)
whorockets
diffs
« on: July 12, 2012, 08:36:26 PM »
hi differs wat we have here is a 73 beddy camper with custom built body running 186 holden thru 5 speed celica box and original diff looks like a swat wagon heres the thing would like to fit a Mk 2 duelly diff setup and front end to finnish the look will the diff ratio be compatable?  if not wat can i do???? cheers
Offline bed767
Re: diffs
« Reply #1 on: July 13, 2012, 01:31:10 PM »
I run a standard holden salisbury diff with standard 3.75 inch offset rims,fit under guards neatly,cheap easy to change ratios.2.60 and up to 4.44:1.  Mine is 3.08:1 with 308 v8 th700 box and 15x10 rims
Re: diffs
« Reply #2 on: July 13, 2012, 04:49:38 PM »
15x10???????? do you have flares
Offline bed767
Re: diffs
« Reply #3 on: July 13, 2012, 05:18:21 PM »
no no need ! diff face to face 1568 m.m. with 10" rims whole thing stays inside body
