  • Dot Guests: 270
Author Topic: VK BLACK 202 3.3LTR  (Read 3391 times)
Offline Kirk
VK BLACK 202 3.3LTR
« on: September 20, 2008, 05:48:03 PM »
How hard would it be to swap my red 202 for this? has a ecu and 5 speed with tailshaft but its in a crumidoore...oops "commadore" Ohh its injected also.
« Last Edit: September 20, 2008, 05:56:04 PM by Kirk »
Re: VK BLACK 202 3.3LTR
« Reply #1 on: September 20, 2008, 07:28:04 PM »
swapping the engine is easy.. and from waht i hear the wiring is reasonably pretty simple hey..
« Reply #2 on: September 20, 2008, 08:41:47 PM »
There is a heap of pics about putting VK EFI and Trimatic auto into a CF at:
http://gallery.oldholden.com/Bedford
The VK EFI has been popular with the early Holden boys for a while and if you look through their forums you find a lot of good info but basically...
The VK computer is analogue and nonprgrammable so it is only good for a standard motor.
The VN computer and harness can be fitted to the VK manifold and will allow performance programming. You will need to use a Camira 2.0 EI throttle position sensor as it turns the same direction as a VK and opposite to a VN.
A new cover will need to be made.
