  • Dot Guests: 287
Author Topic: LX Torana engine sump  (Read 2924 times)
Offline markiimark
« on: July 01, 2012, 10:47:08 PM »
Hello Bugas,
I am putting a new motor in my Van.
Will an LX Torana engine sump fit into a CFS Bedford or will I need to swap it with the sump off my dead motor.
Also, what accelerator cable should I use because the new motor has a Stromberg carby with a 'ball and socket' accelerator connection. The old carby has a 'beer keg' style connection.
Thanks for any help,
Mark
Offline Marky
Re: LX Torana engine sump
« Reply #1 on: July 02, 2012, 07:42:25 AM »
you will need an HQ sump..so as to clear the front crossmember.....
- Bicycle shop..get some wire use for gear changes...pull out old inner ..put new one in...
Creative Media Producer
« Reply #2 on: July 02, 2012, 11:30:48 AM »
i thought the beddies used the eh sump not the hq one??
Offline Marky
« Reply #3 on: July 02, 2012, 12:28:57 PM »
Consult the Beddie Oracle!!
« Reply #4 on: July 02, 2012, 01:05:17 PM »
they used the ht-g sump in 69 >71 then the hq from there .if the sump hits the x member the caster rods need adjusting/replacing as the x member has povoted back  BTW doing this makes the van track better down the road    Cheers Merlin
