  • Dot Guests: 330
Author Topic: Engines - what sorts have you seen running in a beddy ?  (Read 3668 times)
« on: September 17, 2008, 12:20:29 PM »
The topic of Engines came up in another thread, it got me to thinking.
Ive seen a few, holden 173, 186, 202, 253, 308 chev 350, Ford 250 etc.
So the question is  "what sorts have you seen running in a beddy?", and what are the pro's and con's of that setup?
I'll start
I'm running a standard (if not a bit tired) 202.
Pro's - cheap, reliable, simple easy to work on and tune, can get parts almost anywhere. Economical running on Gas its about $35 a week to run.
Con's - No as sexy as a V6/V8, lacks a bit of power for towing my camper around.
Now your turn.
Re: Engines - what sorts have you seen running in a beddy ?
« Reply #1 on: September 18, 2008, 05:54:40 PM »
I have seen a few but the ones that stood out:
Danny's blue CFL with a Ford Cobra Big Block. Very Fast!
The plumbers van from Cessnock with a mid-mounted Chevy Big Block. A genuine sleeper that was also very fast!
One of the boys from BOSCA had a CFS with a worked 350 Chev that he kept blowing up doing burnouts, so he put in a Chev V8 diesel. Still did awesome burnouts but didn't blow up.
Offline LS120
« Reply #2 on: September 18, 2008, 06:50:16 PM »
I'll start
Now your turn.
Have You tried putting A Water to Gas unit in the Camper?? get better MPG & combustion. I'm using one in a 83 CF camper running a 2.3 slopper & 4 speed.
« Reply #3 on: September 18, 2008, 07:02:37 PM »
Welcome LS120
Can you expand on this
I think I know what your talking about but I would be interested in some more info and pics.
Offline LS120
« Reply #4 on: September 24, 2008, 08:52:04 PM »
What do you want to know i can take pics & post if you like but Beddy as my pic is running the Water4Gas unit (cost $45-60) to make.
before i put it in i had a slight cough/miss then when i put it in the rpm idle went from 900rpm to 1000rpm and the miss/cough went away.
going to take it for a long run with & without the unit on. they say you can get from 25% increase in mileage & some have gone as far as 72% increase.
it can be used in Petrol or Desiel motors. ;D
