  • Dot Guests: 286
Author Topic: Gearboxes - what sorts have you seen running in a beddy ?  (Read 5792 times)
« on: September 17, 2008, 12:08:27 PM »
The topic of gearboxes came up in another thread, it got me to thinking (owch that hurts)
Ive seen a few, holden 3 speeds, 4 speeds and autos, Supra 5 speeds, Ive even seen a highace 5 speed in a beddy.
So the question is  "what sorts have you seen running in a beddy?", and what are the pro's and con's of that setup?
I'll start
Standard 3 speed manual.
Pro's - cheap, reliable, simple.
Con's - poor ratio selection, low prefomance, gear linkages wear out over time.
Now your turn.
« Last Edit: September 18, 2008, 12:05:36 AM by Warren »
Re: Gearboxes - what sorts have you seen running in a beddy ?
« Reply #1 on: September 17, 2008, 12:36:19 PM »
aussie 4 speed.. m21 and m20
pro's
tough as! go good behind a v8
con's
shifters suck!! mates of mine have had the gearbox stuck in reverse and 2nd at the same tiime!!! far out!!
ratios are really high.. and there is a big gab between 3rd and 4th..
« Reply #2 on: September 17, 2008, 11:05:04 PM »
I have/had the following Toyota boxes behind a 202 in Bedfords:
Celica alloy case 5 speed gearbox
Pros: cheap
Con: they break even behind a 202, poor gearshift location
Celica steel case 5 speed gearbox
Pros: cheap
Con: poor gearshift location
Supra alloy case 5 speed gearbox
Pros: light, strong
Con: expensive, poor gearshift location
Hiace Diesel 5 speed gearbox with Magna gearshift.
Pros: Cheap, light, strong, custom located gearshift, uses a Supra Conversion Kit to match to motor.
Con: Short box (longer tailshaft needed)
Dyna 4 cylinder Diesel 5 speed gearbox
Pros: strong, gearshift in a good location,
Con: heavy, expensive, non standard shift pattern, 5th gear very small overdrive.
Dyna 6 cylinder Diesel 5 speed gearbox
Pros: strong, gearshift in a good location, 5th gear is a tall overdrive that works well with a standard diff.
Con: heavy, more expensive, non standard shift pattern
Crown 3 speed with electric overdrive.
Pros: light, strong, gearshift in a original location, uses Celica steel case conversion to match to motor.
Con: hard to find, electrical wiring involved, adjustment of overdrive change-points needed, no engine braking available when overdrive is on.
The Crown, and then the Hiace, are my pick of the boxes.
Note that when I do a gearbox conversion, I also move the 202 motor back about 45mm to give room for a power steering pump and thermo fans. I make new engine mounting brackets out of 5mm angle iron that achieve the 45mm relocation and still bolt onto the original rubber mounts.
And yes I have to make a new cover.
« Last Edit: September 17, 2008, 11:31:20 PM by BlackBedford »
« Reply #3 on: September 17, 2008, 11:20:24 PM »
very helpful thanks chris
« Reply #4 on: September 18, 2008, 12:04:49 AM »
Chris
Thanks for your input.
How much longer does the tailshaft have to be for the Hiace gearbox conversion ?
And do you have any pics of th brackets you use to shift the motor back 45mm ?
« Reply #5 on: September 18, 2008, 08:24:42 AM »
Hi black Beddy I see your name is Chris you seem to know a fair bit about gearbox conversions have you had anything to do with autos I would like to fit a Jatco 4 speed Odrive auto to my 202 do you know if they make an adaptor to suit Cheers Reid
hammers_spanners
« Reply #6 on: September 18, 2008, 08:58:12 AM »
Reid Jatco autos are expensive to repair. If you want a 4 speed auto look at the T700 4L60 from a VN or VP Commodore. Castlemaine Rod Shop do have adapters for this conversion.
Craig
« Reply #7 on: September 18, 2008, 06:18:33 PM »
Thank's for that Hammers yknow my brother in law threw a 4L60 to the tip a while back before I got my Beddi if Ida only known anyway thers plenty of them around & he even surjested a 4L60 this arvo so ill have to keep my ear to the ground Cheers Reid
« Reply #8 on: September 18, 2008, 06:41:28 PM »
Sorry Reid, I am not into autos. They are expensive to buy, expensive to repair, use more fuel, and you loose a bit of power, making overtaking a bit harder.
G'day Warren,
I will post some photos and drawings showing dimensions. I cut mine out of C channel of a surprising similarity to the posts used in roadside railing.
The Hiace box is substantially shorter. I will measure the gearboxs to give you and answer.
« Reply #9 on: September 20, 2008, 11:38:50 AM »
has anyone done a borgwarner single rail 4 speed?
just asking as ive got 3 good boxes sittin in the parts shed.
marty
