  • Dot Guests: 328
Author Topic: L/F passenger door  (Read 6669 times)
Bedford_freak_nz
Re: L/F passenger door
« Reply #10 on: June 08, 2012, 03:56:26 PM »
Not too sure about that  one.. But if anyone else knows if they are compatible please let me know as I want my van on the road asap
« Reply #11 on: June 08, 2012, 05:22:25 PM »
The mk1 came out with 2 versions, the early had the push or pull inside door handle and the later came with the pull out inside handle (like the mk2), the mk1 also came in two different inside variations around the door handle/window winder.
The real early ones had the steel screw in panels with the 'lump' across the top section of the inside of the door, the later came out with a door trim (cardboard).
The mk1 doors came out with a thin steel door pull, while the facelift came out with a curvy hard plastic pull and the mk2 came out with a hard squared plastic one.
A lot of mk2's came out with black outside handles too.
The real early mk1 didn't come out with a key barrel in the passenger door
The outside shape and even the guts of the doors are the same.
Offline tiwaz_nz
« Reply #12 on: June 08, 2012, 05:53:19 PM »
you can use one of my doors till you get your own if you want
it a early cf can bring it to you and try it if you want
Bedford_freak_nz
« Reply #13 on: June 08, 2012, 06:08:21 PM »
The van is at the customizer at the mo and would rather get my own rather than swapping them over again but would be interesting to see if they are compatible
Offline tiwaz_nz
« Reply #14 on: June 08, 2012, 06:23:26 PM »
cool ...
mine is an early model
no key hole on passenger door
booster master only had one outlet pipe
heater is the round model and went uo to the vents in the bonnet
mite be other things ... but not sure of the vans year
just im me and arange sometime to come up
what you getting done to the van at the customizer ?
any pics ?
Offline tiwaz_nz
« Reply #15 on: June 14, 2012, 05:47:15 PM »
