  • Dot Guests: 378
Author Topic: Need mechanic for gearbox change!  (Read 12060 times)
Re: Need mechanic for gearbox change!
« Reply #10 on: September 17, 2008, 11:56:41 AM »
Morgz
Do you know what type of box you have (M20 or M21) and what have you decided, Just rebuild the clutch or throw in a new box?
There are other types of boxes that can be used have a look here for mor info on boxes gear linkages etc
What way you go determines how long it will take and how much it will cost you.
« Reply #11 on: September 17, 2008, 12:15:30 PM »
hey warren he had already decided to go supra 5speed when i spoke to him yesterday.. because of the lower 1st and overdrive as well.. he is running a 3.5 diff.. so that should be good addition to his beddy.. ben
« Reply #12 on: September 17, 2008, 12:25:04 PM »
Thanks Ben
So the gearbox mount (crossmember) and shifting linkage will need to be considered as a part of the change over then.
I think Blackbeddy has mentioned the Magna cable set up.
I'm not a big fan of the gearshift poking through the floor 2 feet behind you sort of thing.
« Reply #13 on: September 18, 2008, 01:10:49 AM »
hey Morgz, welcome to the sitebuddy, love the comment 'bout slappin round the head (got the image :D)
Iv'e had several different combo's with the supra, you might find the first to be too low at first,depends on what what diff ratio you running???what rims and tyre profiles???
 They are a bloody good box, nice smooth gear changes and  not too weak either.The shifters a bit of a drag tho, get one of the boys to weld an extension onto your shifter, it will make the world of diiference, when I get to it (very soon) I' m making a remote shifter for mine, I'll keep all  patterns and templates, with measurements for any who need them. If it freaks you out  don't fret, just an excuse to change to 15" rims ;D.
I'll keep ya's posted!!
Offline Morgz
« Reply #14 on: September 24, 2008, 01:34:32 AM »
Hi Warren and Dano, thanks for the info.  I've been talking to Jeff @ Dellows about the conversion.  He tells me he's done exactly the same conversion in the past to his old Beddy and has built me the kit accordingly.  I have a custom diff at the moment, 3.5 if I remember correctly (not sure what type of 4 speed box I'm running) and 1st gear is veeery long.  Like I said before I've become used to it and drive it accordingly but when friends and family want to borrow it to move stuff (as they always seem to do) they never seem to appreciate when I tell them "DON'T rev hard on the clutch, be patient, 1st is long!".  So now I have a burnt out clutch and a good reason to make the change to a 5 speed.  The shorter 1st (I'm going for the w59 Supra with the 3.95:1 1st gear) should make for a nice comfy take off compared to what I have currently and the overdrive will be great for the freeway.  As for my tires I've changed to a holden stud pattern and I'm running 15" mags with HQ front end and discs, tire profile is......ummmm, can't remember but it ain't huge, nothing 'unusually' high or low.
I know what you mean about the shifter Dano, even with the 4 speed it's sitting back too far to be comfy, that's why a mate hammered on a piece of bent steel tube onto the shifter for me when I changed the engine over years ago.  It's not pretty yet, I'm planning to stick a knob on the end of it and cover it with something nice and fabric-y to make it look more like a shifter. Most people think it's the hand brake when they see it first time! I find it quite easy to use so I'll keep it and wack it onto the new box and see if it's ok as is.  There's always a solution ;)
@Warren:
Do you mean clutch cable or speedo cable when you mention the Magna set up? I've got a speedo cable coming from Dellows as part of the kit.
Not sure about cross member and linkages.  I'll ask some more specific questions as we get closer I guess.
Once again thanks for your help guys, much appreciated.  At some point I'll get some pics and a history of my beast up so I can feel a little more like part of the family :)  Cheers,
Morgz
« Reply #15 on: September 24, 2008, 11:15:54 AM »
Hey Morgz
Re the Magna cable thing, Chris (BlackBeddy) has talked about it in the past, and from my understanding it is a cable operated Gear shift mechanisim, the idea being that you can mount the gear shift anywhere you want and the cables connect to the gearbox.
I havent seen one in action but by the sounds of it they are a simple solution to the akward shifter position.
My old valiant had a cable (push button auto) that worked a treat.
Chris may be able to supply more detail on this.
« Reply #16 on: September 24, 2008, 11:39:33 AM »
Here is a post on the old site about a Mechanical linkage, the cable option would take a lot less time to adapt than this I think.
Although it is an excellent solution
Offline Morgz
« Reply #17 on: November 14, 2008, 06:48:14 PM »
Success!  Just wanted to say a huge thanks to Ben and Craig for helping me put in the new box, it was much appreciated and I thoroughly enjoyed myself, despite the odd hurdle I think it all went rather well.  I'm still in NZ but I can say that in the couple of drives I took it on before I left it was feeling real good.  Will hopefully test out the overdrive gear soon and post some pics somewhere so you can all have a look at my little beast.  Cheers fellas.
« Reply #18 on: November 16, 2008, 07:59:56 PM »
G'day
Sorry for the late reply.
The Magna gearstick is used with a Toyota Hiace diesel alloy case 5 speed. It uses the same conversion kit as a Supra and is a light, very strong box. It is a very short gearbox and the tailshaft will need to be extended to fit. It has a linkage gearshift setup on the side of the box rather than a gearshift poking out the top. A Magna manual gearstick and cables are then used so the gearshift is of a short length and can be mounted anywhere you want it.
« Reply #19 on: November 18, 2008, 07:21:55 AM »
no worries morgan.. thanks for everything had a great time helping you out. cheers
