  • Dot Guests: 260
Author Topic: Can I... Have a column shift auto  (Read 13483 times)
Re: Can I... Have a column shift auto
« Reply #20 on: July 04, 2012, 08:12:02 PM »
if you get a extra long cable made up you can put the shifter in the dash.
positioning the shifter only depends on how long your cable is.
« Reply #21 on: July 04, 2012, 11:30:19 PM »
If you are going to put it on the dash then you could use a Quick silver shifter and if you need a longer cable Flexidrive could make one for you
« Reply #22 on: July 05, 2012, 02:15:37 AM »
What about a push button auto like the AP5 valiant?
« Reply #23 on: July 05, 2012, 09:24:18 AM »
I have a Q. so you can stick your shifter anywhere if you use a cable. My mechanic was saying that cables can break after a while with all the use they get, he did say that the straighter the line the better, the more bends or curves the more chance of it wearing out quicker. Can you get a heavy duty one made.
« Reply #24 on: July 05, 2012, 01:47:46 PM »
preoil your cables before installing them George, there isnt much friction on gear select cables so wear would be minimum, once its in drive it usually stays there for the duration of the trip.
 any cable maker could make up heavier duty cables.
as long as you rout your cable up into the enine compartment then through the firewall like the speedo or clutch cable there shouldnt be too much angles to worry about.
cables like graduating curves instead of sharp ones.
cheers marty
« Reply #25 on: July 05, 2012, 02:28:51 PM »
Thanks MTY, that helps a lot, being i am doing a custom shifter and location set-up that might make it easier. So can i assume that with the bar instead of the cable you would pretty much need to have the shifter over the top of the box for them to work smoothly.
« Reply #26 on: July 05, 2012, 05:26:19 PM »
yeah id say so George, you might just snooker it though?
you never know hey.
id be going cable if it was me though.
lot easier
« Reply #27 on: July 05, 2012, 06:11:03 PM »
I've seen in the states electronic push button shifter units that run off a servo possibaly Lokar check with Armadale Auto Parts
« Reply #28 on: July 06, 2012, 04:37:41 AM »
Hey George, B&M do a conversion kit for the TH700 that changes the linkage setup to a cable mount. Just a bracket that fastens under the trans sump, another that fastens to the shifter mechanism on the side of the trans and a couple of little odds and ends to connect the cable. Got one of these for mine. Just looking at modifying the Honda Astor shifter I found to connect the cable to however if that goes sideways I'll have to look at a different shifter.
http://bmracing.com/?wpsc-product=bracket-lever-kits-general-motors-th400-350-250-2004r-700-r4
Actually they've got a whole lot of stuff you can break your TH700 with...
http://bmracing.com/?wpsc_product_category=transmission-accessories-kits
« Last Edit: July 06, 2012, 05:35:03 AM by Rogue Trooper »
Offline Stangas
« Reply #29 on: July 16, 2012, 12:13:43 PM »
yeah you guys are right..
i am purchasing a lokar shifter with the floor mount cable driven..  it can be mounted anywhere as long as the cable reaches.
that will buy me enough room.  and it looks pretty specky too..
tossing up on the 16' or the 23' shifter handle..  the 23 has 2 bends in it so will probably be better.
-BED 253-
