  • Dot Guests: 186
Author Topic: Diff's  (Read 15488 times)
Re: Diff's
« Reply #40 on: May 15, 2012, 05:38:42 PM »
Yep Harry got nothing looked under all the trees etc ;D Tried BNT, 9" yes but not the same width, Cheers
Re: Diff's
« Reply #41 on: May 15, 2012, 05:56:43 PM »
Can someone measure the width of the 9" drum please ( rear ) or depth to some.. Thanks
Offline waikatostocky
Re: Diff's
« Reply #42 on: May 16, 2012, 06:11:17 AM »
Hay Bas,I may have 2 drums on a van i had for parts i will try to get around there today after work and see if i can get them off for you
If they are 9" drums you can have them.I come up to akld on a sunday in a truck so if i have got a run up there this sunday if you could meet me at the BP truck stop on the motorway i can drop them off for ya.
Cheers Paddy
be safe out there
Re: Diff's
« Reply #43 on: May 27, 2012, 10:56:55 PM »
Anyone come across any 9" drums laying around yet............. ??? ??? ???
Re: Diff's
« Reply #44 on: May 28, 2012, 07:27:32 AM »
Ok looks like I am going to give my engineer skills  ??? a working going to graft the 10" backing blate on to the 9" housing, after all once this is on, evrything is connected to this right....... ??? Going by all the measurements I have taken, just have to machine up a part plate to weld on to the old housing, as the 4 bolt holes on the 9" line up with the 10" plate.  ;) But ofcourse it can't be that simply can it or am I missing somethig. ???
Re: Diff's
« Reply #45 on: May 28, 2012, 07:41:05 AM »
i have seen this done before bas. he just used the 4 bolt holes and didnt worry about the other 2.
Re: Diff's
« Reply #46 on: May 28, 2012, 09:27:34 AM »
Thanks Ben, 4 bolt holes don't line up as I thought, but new ones can be drilled in the backing plate ok.............. :D :D :D
Re: Diff's
« Reply #47 on: May 28, 2012, 11:29:39 AM »
oh he must have rhemed out something then ay.
youd want it to be pretty spot on wouldnt ya? otherwise the brakes wouldnt work too good..
« Last Edit: May 28, 2012, 01:09:57 PM by ben »
Offline Bedford Fever
Re: Diff's
« Reply #48 on: May 28, 2012, 01:22:30 PM »
 Hey Ben think you saw it on my van.
 Just had a quick look under van , have 10 inch beddy drum brakes bolted to the 4 bolt 9 inch axle.
 Dont have a camera right now on me , will try take some later. But i can just see half of the extra 2 holes that would of bolted to the
 6 bolt 10 inch axle.
   Cheers Frank
Re: Diff's
« Reply #49 on: May 28, 2012, 04:37:31 PM »
Ok guys, just in case you need this for future use, 10" onto 9" is a go, just sloted the holes and welded them back up to leave the new postion of the hole, done 4 bolts but will shoot down and machine up a part plate and weld it in to align the 2 extra holes, don't think you have to but will as I'm fussy. :) Diff and a new set of feet on its wayyyyyyyyyyyyyy :D :D :D :D :D :D
« Last Edit: May 28, 2012, 04:39:17 PM by Bas / NZ »
