  • Dot Guests: 319
Author Topic: Diff's  (Read 15492 times)
Offline Jock
Re: Diff's
« Reply #10 on: May 04, 2012, 10:27:59 AM »
You wouldn't want 4:1 behind the commodore.
I second that, the 4.1 = massive revs at 100 clicks, even with a transmission with an over drive.
I started with the 3:08 but wasn't happy at 100kph (at 2300rpm)
3.08 is a little on the low side, not quite enough poke for hills etc
so went to 3:3 (i think it was)
3.3 or what I am currently running 3.45 is a pretty good combo.
I think that anywhere between 3.3 and 3.7 (depending on what centre you can find) would be a pretty happy medium.
Re: Diff's
« Reply #11 on: May 04, 2012, 10:30:44 AM »
Bas, ph Harry on 818 3728 he's just in Kelston, he has everything bedford. be warned though he'll talk your ear off and is always ready with a joke or two
He's got a sliding door bedford there and even an old thames van (and original triumph motorbike), as well as some brand new, boxed (or in crates) Indian motorbikes - ex army (they down matamata), think he has about 6 of them as well as a barn full of classics (he wont part with any)
Re: Diff's
« Reply #12 on: May 04, 2012, 09:26:08 PM »
Ok 5.1 at 100km revs 2100 thats what I get at the moment with the TH700 with the duel wheels
« Last Edit: May 04, 2012, 09:27:53 PM by Bas / NZ »
Re: Diff's
« Reply #13 on: May 04, 2012, 09:28:40 PM »
David, will he have 9" drums ?
Re: Diff's
« Reply #14 on: May 05, 2012, 07:01:26 AM »
9" are swb (4 bolts holding backing plate) and 10" are usually lwb (6 bolts holding backing plate)
Re: Diff's
« Reply #15 on: May 05, 2012, 03:25:38 PM »
9" Drums anyone got a couple of spare...And where do I get a new  pinion oil seal
« Last Edit: May 05, 2012, 03:27:53 PM by Bas / NZ »
Re: Diff's
« Reply #16 on: May 05, 2012, 06:03:56 PM »
Ph Harry, he has everything up there, if he hasn't he should be able to get it for you.
Re: Diff's
« Reply #17 on: May 05, 2012, 09:52:10 PM »
Thanks david, been down for the last couple of days ( you understand why), couldn't even make it to Kelston, when I'm back on my feet, will give him a call. Bas
« Last Edit: May 05, 2012, 10:14:31 PM by Bas / NZ »
Offline wraithknight
  • love my bedfords
Re: Diff's
« Reply #18 on: May 06, 2012, 02:20:16 PM »
just so i know wat is the ratio for a cf2 diff
  • love my bedfords
Re: Diff's
« Reply #19 on: May 06, 2012, 02:21:50 PM »
and would a 3.55 10 bolt be ok to use with a 202 with trimatic gear box
