  • Dot Guests: 276
Author Topic: Speedo Issues  (Read 7500 times)
Offline pirate13
Speedo Issues
« on: April 30, 2012, 04:20:37 PM »
Hi Guys,
needing some help if possible regarding the cable connection for my speedo i cannot get it to connect.
this is the current connection from the 4 speed cable but it does not fit.
how have others combatted this issue?
new speedo or is there something im missing or dont know.
any help would be rad
thanks guys!
Drink up me hearties yo ho
Re: Speedo Issues
« Reply #1 on: April 30, 2012, 04:31:53 PM »
Did you replace a 3 speed with a 4 speed ? if so it should bolt straight in.
When you say won't fit, just what do you mean ?
you also need the plastic gear that the square end of the cable goes into, several different colours for different ratios - allowing for different ratio diffs.
Offline pirate13
Re: Speedo Issues
« Reply #2 on: April 30, 2012, 04:43:51 PM »
Has always been a 4 speed,
the connection is completely different as per this photo.
when i received the van it was simply screwed in by a cover but no connection was being made.
Ross.
Offline Jock
Re: Speedo Issues
« Reply #3 on: April 30, 2012, 04:48:14 PM »
What colour cog for a 3 speed trimatic with a 3.45 borg warner centre and 14 inch rims?  :)
Re: Speedo Issues
« Reply #4 on: April 30, 2012, 05:18:36 PM »
White, made mine run ture
Offline Jock
Re: Speedo Issues
« Reply #5 on: April 30, 2012, 05:58:04 PM »
Bas you are a legend! Thanks mate.  ;D
Offline Jock
Re: Speedo Issues
« Reply #6 on: April 30, 2012, 06:04:19 PM »
Bas is this the correct part:
SG1007
GEAR SPEEDO DRIVEN AUS 3&4 SPD TRIM 20 TEETH WHITE
AU$16.85 EA  Inc GST
http://www.rarespares.net.au/rarespares/ProductPage.aspx?product=SG1007
Re: Speedo Issues
« Reply #7 on: April 30, 2012, 06:23:06 PM »
Well a long time ago now, just went to holden and was told the white cog was the one to use, did it and tested speedo with a freinds car in front and was a perfect match., But yes it was a white one. hooked up to standard CF dash / speedo, If you hang off will pull cable off tomorrow and double check.
Offline Jock
Re: Speedo Issues
« Reply #8 on: April 30, 2012, 11:41:34 PM »
That would be great Baz. I'll hold off until I hear back from you. Cheers. Jock
Re: Speedo Issues
« Reply #9 on: May 01, 2012, 03:27:50 PM »
Jock, wasen't able to get under the van to have a look, van is up against a wall (drivers side) under cover and is droped down to fit under the cover, won't be moved for a couple of months, but very sure it was the white one.... Bas
