  • Dot Guests: 240
Author Topic: GRUNT HUNT 202  (Read 23742 times)
Re: GRUNT HUNT 202
« Reply #40 on: November 10, 2008, 09:32:59 PM »
The economy of a turbocharged motor is inversly proportionalto the weight of your right foot.
At lower revs the exhaust gas is moving slower so the compressor (turbo charger) is spinning slower, making less boost, and therefore using less fuel and being more economical.
As the revs rise there is more exhaust gas flowing, spinning the compressor faster forcing more air/fuel mix into the motor.
Drive sedatley, use less fuel, put the foot down, use more fuel.
Turbocharging is a good use of an otherwise lost force (exhaust gas) and its power increases logrithmacally with the speed of the exhaust gas - more revs - more gas flow - more boost.
Where as supercharging is a direct connection to the crankshaft and actually consumes power to drive it, and can only give a set boost that is determined by the drive pulley ratio's
If I remebr correctly it was common for the 3xy roller vans to be turbo'ed sixes rather than V8's - it was a simple bolt on horse power thing.
Tweaker
Re: GRUNT HUNT 202
« Reply #41 on: November 10, 2008, 10:47:43 PM »
Economy ::) ::) ::) I knew him once....... :P Hang on that may have been a dream I had or I  might be getting confused with the other dream which had twin turbos in it. ::)
 ;D
Offline photol
Re: GRUNT HUNT 202
« Reply #42 on: November 11, 2008, 08:40:33 PM »
Thamks Warren for an excellent explanation....Tweaker have they increased your medication???....I'm moving to your place..... :D
....it's not what you see....it's what you think....you see.
Tweaker
Re: GRUNT HUNT 202
« Reply #43 on: November 11, 2008, 10:08:39 PM »
Lol....... Oops that reminds me.......
