  • Dot Guests: 379
Author Topic: Reviving Barry  (Read 35766 times)
Offline Marky
Re: Reviving Barry
« Reply #20 on: May 09, 2012, 10:28:54 PM »
I've just completed the LJ/XB brake conversion.....
and now my back brakes lock up if i hit em hard
options are
1. put softer pads on the front...
put in a proportion valve....that i have in the shed...
Creative Media Producer
Offline slikgm
  • Nothing is straightforward on a Beddie!
Re: Reviving Barry
« Reply #21 on: May 09, 2012, 11:47:54 PM »
Yeah they say that can happen,I'm going to get one on hand in case that happen s then I will fit it if needed Also Marky .your SWB Borgie  diff looks good in my Van ,I will try and Post a pick
Offline Marky
Re: Reviving Barry
« Reply #22 on: May 10, 2012, 08:37:59 AM »
Great!! wish i had never sold it now!! hahah
Offline Jock
Re: Reviving Barry
« Reply #23 on: May 10, 2012, 09:21:30 AM »
Also Marky your SWB Borgie  diff looks good in my Van ,I will try and Post a pick
 :-X :-X :-X
Offline Jock
Re: Reviving Barry
« Reply #24 on: May 10, 2012, 09:22:36 AM »
I've just completed the LJ/XB brake conversion..... and now my back brakes lock up if i hit em hard
options are
1. put softer pads on the front... put in a proportion valve....that i have in the shed...
No good!
Did anyone else have this problem? I didn't know I was meant to fit a proportioning valve?  ??? ??? ???
Shi-za.
Re: Reviving Barry
« Reply #25 on: May 10, 2012, 02:12:06 PM »
you can get an adjustable proportioning valve. but there illegal cause people lock the back brakes off with them (cause no ones ever used vice grips before???)
or get smaller bore sized rear wheel cylinders. if you dont know what your doing its real guess work... i dont know what im doing lol so its guess work:)
Re: Reviving Barry
« Reply #26 on: May 10, 2012, 02:51:39 PM »
Everything on a Bedford is Guess work......... ;)
Offline Sweet Shock
Re: Reviving Barry
« Reply #27 on: May 10, 2012, 09:06:41 PM »
Had the same problem and hoppers stoppers changed wheel cylinders and still the same.  Adjustable Proportion valves arnt illegal but they have to be put in a position that accesability is hard to access. I put my horn over the top of mine and past engineer and rwc
Re: Reviving Barry
« Reply #28 on: May 10, 2012, 09:48:19 PM »
oh everyone i talk to says there illegal?
Offline Marky
Re: Reviving Barry
« Reply #29 on: May 10, 2012, 10:27:33 PM »
my mechanic and mentor tells me..changing wheel cylinders diameters is not the solution...
he recommends to try out softer pads on the front...1st...
then if that doesn't change it put the valve inline...
.i have a valve in the shed..not sure what its is off..but..with the new brake set up
i can put my head into the windscreen if I'm not careful....
i tried out the new brakes first on a grassy patch...to see how even the pressure to each wheels is.....
.no matter how i braked it..with  different pressure......... the backs always lock up first...so its a safety issue for me for sure
but having a van that the backs lock up is probably more illegal than the proportion valve...
can't remember which set on toranas had the valve..but there was one on ebay a while back for $50.... ..
i wil be fitting it to the van...on the weekend...
Happy Vanning
