  • Dot Guests: 372
Author Topic: Reviving Barry  (Read 28635 times)
Re: Reviving Barry
« Reply #30 on: May 10, 2012, 10:40:39 PM »
just dont stand on the brakes as hard?
Re: Reviving Barry
« Reply #31 on: May 10, 2012, 10:44:03 PM »
thats all good untill you have an emergency situation and your on auto pilot you brake hard and  lose control cause its all locked up.
Re: Reviving Barry
« Reply #32 on: May 10, 2012, 10:47:28 PM »
guys you might need to check if you have the right master cylinder the 4 wheel drum master has a 60/40 bias spring and the disc/drum master has 70/30 bias hence the rear locking first you are actually not applying enough line pressure to the front 60% as opposed to 70% also theres a reason the master has 2 outlets for the front brake as the calipers displace a lot more fluid  .hope this helps   Cheers
Re: Reviving Barry
« Reply #33 on: May 10, 2012, 10:54:47 PM »
Most 4x4 wagons have a self proportioning valve in the back. Maybe retro fitting something like this would be helpful to you. It certainly help if you started putting some load in the back.
Re: Reviving Barry
« Reply #34 on: May 10, 2012, 11:58:20 PM »
Hilux 4x4's have a brake prop. valve that mounts to frame & diff might be worth looking at
Offline Marky
Re: Reviving Barry
« Reply #35 on: May 11, 2012, 07:36:39 AM »
[/quote]
exactly ben...im fine to drive around and have done a few emergency stops and a lot of testing before i hit the highway....
my new brakes are excellent ..just want them to be perfect..... ;D
Creative Media Producer
Re: Reviving Barry
« Reply #36 on: May 11, 2012, 07:53:47 AM »
I'm alittle lost here, may be because I haven't read the full post, but what about the set up the duel wheel jumbo is using on the rear.
Offline Jock
Re: Reviving Barry
« Reply #37 on: May 11, 2012, 10:42:41 AM »
Merlin,
Are you advising that I run a seperate line to each front caliper because at present I am only running one line to the front and splitting it to each caliper. The master cylinder that I have is PBR part number: P6258A
How do I know what bias spring I have?
Jock
Re: Reviving Barry
« Reply #38 on: May 11, 2012, 10:49:59 AM »
OK I SEE WHAT YOU ARE TALKING ABOUT NOW........
Re: Reviving Barry
« Reply #39 on: May 11, 2012, 11:09:40 AM »
all 3 of my vehices (SWB bedford poptop, holden rodeo, nissan 4x4) lockup if i stand on the brakes hard enough, and you just keep the pannic pressure on them,
the SWB bedford poptop has " No preportioning valve" holden HQ disks on front, standard bedford master cylinder and power booster, and standard bedford drum brakes on the back. (HQ stud pattern front n back)
(anyone know how much it is to redrill highway diff axles from std bedford to HQ Studpattern? ????)
brakes are perfect, no dramas at all
i dont think u should be on auto pilot when driving any vehicle.
if i have drama,s with brakes i just take the vehicle to a brake service centre, then you have a warantee, if anything goes wrong.
sounds like Merlin knows the go with the disc/drum master has 70/30 bias spring,
 but ive got no idea what spring is in my brake system.
« Last Edit: May 11, 2012, 12:30:11 PM by mty »
