  • Dot Guests: 229
Author Topic: ford ef 250 into beddy cf250??  (Read 5515 times)
« on: September 13, 2008, 05:58:56 PM »
got a friend selling a ford ef falcon.. for $250. apparently the only problem is the computer is kaboom! $100 worth aparently
its had the straight 6 250 in it.. with overdrive box..
am considering a repower in my black beddy.
there is people that have done this conversion yeh? and i dont want no electronic speedo and any new looking stuff inside my beast. cant imagine even considering anytrhing by Ford! but they are extremely cheap ion gas so its an option.
anyone have anythoughts on the wiring side of things? and what wiring is needed for the motor to run?
hammers_spanners
Re: ford ef 250 into beddy cf250??
« Reply #1 on: September 13, 2008, 08:22:53 PM »
Ben as long as you dont plan on running petrol you could leave the fuel injection stuff on. Just hook up the gas to it. Wiring it is straight forward if you are not using the efi.
Offline snow
« Reply #2 on: September 14, 2008, 02:00:30 AM »
Hey ben if you don't have much luck here go to this forum and look in the aussie ford sixes theres a few that done converson http://fordsix.com/forum/index.php?sid=f8adeb28004535186d1091426f3c6d93  otherwise  you should get some support with the wiring
cheers snow
« Reply #3 on: September 14, 2008, 07:15:43 AM »
hey thanks snow!! had a breif look.. sooo many posts on that site. i dont have much chance in finiding what im looking for now.. so later. thanks
and hammers would i still be able to achive the same sort of economy without the efi? cause thats really why im doing it.. for cheap fuel!! yeh i dont care much for petrol hey..
« Last Edit: September 14, 2008, 07:18:42 AM by ben »
« Reply #4 on: September 14, 2008, 09:38:19 AM »
You'll find that you wont have as much torque and power all though the rev range without the computer connected. The inlet manifold on those engines has a nice  valve arrangement that opens and closes to effectively adjust the runner length. Without that the engine wont be half what it used to be.
I've used these engines in more conversions than I can count on my fingers and toes and all of them ended up with having the computer wired.
« Reply #5 on: September 14, 2008, 08:59:13 PM »
A mate of mine reconditions cylinder heads and he says that he gets lots of Falcon heads in for rebuild. If you are going to use one make sure you have good cooling.
