  • Dot Guests: 243
Author Topic: Help Please  (Read 5724 times)
Re: Help Please
« Reply #10 on: March 11, 2012, 04:04:58 PM »
Baz
To quieten down your pod filter, find an cheap alluminium pot that fits over the pod, allow enough distance at the base for air flow - say 12mm alway around.
That should quiet it down some and protect the filter as well.
Re: Help Please
« Reply #11 on: March 11, 2012, 05:48:54 PM »
Thanks Rougue, pulled a wiring diagram off a link on old holden, the man.. works fine, the fan might be on most of the time for now, but it does get hot inside that engine cover, and can turn it off for motorway use, will take it to an auto elec later on as I have no relay / fuse there at all and also looks like the link up on the ecu is not there either. Yes the after market is hard to seal but I guess worth a try.
Yes I used 80mm Marley if you want to mount it directly to the throttle body it's a perfect fit, and takes the 77mm pod filter. Just got to paint it Black ;)
Fitting a relay is a piece of piss. You just need to identify the pin on the ECU that sends the control signal to the relay and Bob's your aunt's live-in lover. Would be tidier than the external unit.
Matte and I had a bit of a conversation about using Marley spouting in my van thread although I'm buggered if I can find where now as I was using it to set up my air intake as well. The PVC it is made out of is not heat resistant and you could end up with it melting in your engine bay especially as you say it gets quite hot in there. I've used the Marley to model mine but am going to make it up out of steel. I may heat wrap it to keep the air temperature down as well. Matte had an experience of that stuff melting over an engine. Wasn't good.
Baz
If you do that then you defeat the purpose of the pod filter and all it will be doing is sucking in the heated air from the engine bay however if you fitted a shield around it but facing the other way then you would still get cold air flowing into it. It may cut down the noise a bit but it would also protect it from sucking in hot engine air when your're sitting idling at the lights so would probably perform better. More of a cold air box.
Re: Help Please
« Reply #12 on: March 11, 2012, 07:36:17 PM »
Guess it could melt, but I have good clearance at all points, so will see how it goes, but if you are getting a good flow of cold air through it, it will lower some of the heat, looks like I will be heading back to the VN box any way, You can all ways form a half round heat sheild under so it runs between the motor and piping, the heat from the engine bay itself will do very little as this stuff stands up to a hot Auckland summer day  :D not sure what it's like down your way  ;) but at the end of the day I want the air to flow freely up into the engine bay and the bedford has a big grill area, will keep an eye on it any signs of melting and the box will be next on the list....
Yes a heat rap around it would be a good idea, that way if it melts, it would be contained... ;D ;D ;D
« Last Edit: March 11, 2012, 07:45:50 PM by Bas / NZ »
Re: Help Please
« Reply #13 on: March 12, 2012, 12:03:47 PM »
David, when / how often does your thermo fan come on / cut in Cheers Bas - think they are set to about 110, talked to a guy the other day with one in his van / v6 3.8 he said his fan stoped working and could not run the van for more than 3 mins without it heating up., stange since I changed the termostat the temp guarge works
« Last Edit: March 12, 2012, 12:06:05 PM by Bas / NZ »
Re: Help Please
« Reply #14 on: March 12, 2012, 04:56:12 PM »
it's about a 1/4, or 2mm above it on the VN gauge
comes on whenever it hits the mark, if stuck in traffic it stays on for a few minutes then cuts out and comes back on in another 5 mins or so.
The year before last I took it to kumeu and got stuck in the traffic for an hour, it never once went above the mark where the fan comes in. down the motorway it never comes on as engine runs to cold - to much air coming through grill
Re: Help Please
« Reply #15 on: March 12, 2012, 05:16:56 PM »
Ok need mine on all the time around town can switch if off for a while but temp goes up back on temp straight back down, on the motorway don't need it at all. Thanks
After 2 hous of driving / one hour in town, Plastic pipe / intake did not get hot, just luke warm.. if any
« Last Edit: March 12, 2012, 05:19:12 PM by Bas / NZ »
