Finally got it all typed up , as there are some 13 pics i will put them in my gallery (page 6)
VN disc brake on standard Bedford diff (long wheel base single wheel ) I have the complete VN doner car so V6 motor/gear box and all the electrics will be transplanted This is a prototype and wooden spacers/some metal brackets will be refined and upgraded. To start with you need to remove the backing plate from the bedford diff, cut the centre out of the plate so that you end up with a sort of spacer, cut it the same size as the outside of the diff housing pics 1 and 2.
obviously do both sides at the same time unless you want to practice on one side then do the other side. Before removing the the vn backing plate measure the distance between the front face of the backing plate and the front face of the axle where the disc fits pic 3 so that when you later make the spacers they are the correct thickness to make the calipre and rotar operate correctly.
Next take the backing plate from the vn ( it is the part that holds the brake calipre and the hand brake shoe components) mark the plates drivers /passenger side, this is necessary for later on.. weld up the 4 bolt holes and grind the weld flat both inside and outside. Pic 4,5 and 6.
Now using the cut down bedford backing plate,place this over the vn backing plate(the flat section will be on or over the slot for the hand brake mechanism vn). Mark the new 4 bolt holes to suit the bedford pattern. This may be a bit fiddley, should have the centre circles overlapping about 3 to 4 mm. And the new top bolt holes will just touch holes you previously welded up It is important to have the holes in the correct position. Sorry I didn”t take a pic of this.
Next part is to cut the backing plate into 2 pieces so that it will fit over the axle between the bearing securing cover and the end of the axle. Pic 7.
now this cut is a bit flexable, and is offset towards the top of the plate. Having said that I made the cut about half way between the top bolt hole and the hole that locates the pin for the brake shoes. Pic 9.
mark the line for the cut, BEFORE YOU MAKE THE CUT you need to drill and tap a hole ( I used a 5mm bolt) each side of the cut and attach a small plate to keep the backing plate circular pic 8.
this small plate can be removed and the backing plate cut into 2 pieces.
Now working on the drivers side of the bedford diff use the passenger side vn backing plate and bolt it to the diff housing (need longer bolts) pic 10
also have to bolt on the small plate over the 2 joins in the backing plate( the slot in the backing plate will then be clear of the diff housing (flat part of diff housing thats why I changed passenger and drivers side backing plates over ) so the hand brake mechanism continues to be operational pic 11.
Measure the distance between the face of the backing plate and the face of the axle and make spacer blocks the difference between the 1st measurement you made of the vn (pic 3) and the one you now have on the bedford it will be about 10 to 12 mm. Pic 12
(wooden spacer can be trimmed and shaped to fit then when you have the correct size make your steel spacer to the finished size pic 13)
With the backing plate and the two small plates attached to the backing plate, the temporary spacers the fun bit starts with fitting the handbrake shoes. There isn't much room but it does fit. The brake shoe may just catch on the lower bolts but with the slightly shorter correct size bolts it should clear. Pic 14
The caliper and the splash plate can be attached for a dry run see what it looks like. The bedford axle will need to be machined down for the rotar to fit and the vn stud pattern drilled. I will add the pics for this when I get this part done. The calipre will be to the rear of the axle and the handbrake mechanism is now at the top of the axle (instead of the bottom on the vn) and as a result of changing passenger and driver sides the handbrake operates correctly pic 15.
I hope that this is helpful and of some interest to all.
