  • Dot Guests: 298
Author Topic: Jumbo Diff ?  (Read 9331 times)
Re: Jumbo Diff ?
« Reply #10 on: March 02, 2012, 02:11:46 AM »
Anyone got a smart Idea to remove stuck axles, have used a slide hammer, no luck, guess I could heat up the bearing to free it, but may be not such a good Idea?
or if its really stuck put an old wheel on and smack the back of it with a sledge hammer.. work your way around. ive only ever had 1 out of about 10 stubborn axels not come out this way. and i ended up leaving it in and it went to the scrap heap.
Re: Jumbo Diff ?
« Reply #11 on: March 02, 2012, 06:11:03 AM »
And once you get the axle out treat the bearings like a new born baby as they are about $200 each
Re: Jumbo Diff ?
« Reply #12 on: March 02, 2012, 08:55:04 AM »
heat the back of the bearing housing.
Re: Jumbo Diff ?
« Reply #13 on: March 02, 2012, 10:57:11 AM »
and use a 5ft length of chain fixed onto 1 of the studs with the wheelnut. (make sure the nut is tightened right up so not to damage the stud)
d/shackle a big heavy steel bar on the loose end and use it like a slide hammer.
(the steel bar needs to be very heavy)
it works every time for me..
cheers marty
Re: Jumbo Diff ?
« Reply #14 on: March 02, 2012, 03:18:45 PM »
ive been told you can damage the housing this way. so not adviseable
Re: Jumbo Diff ?
« Reply #15 on: March 02, 2012, 04:05:52 PM »
Thanks for all you help guys, went with the wheel set up, gee it felt good to beat the sh...t out of it, haven't done that for a long time. Worked a treat, just stuck now with the pinion nut have a socket but it's  to far down, need a tube socket or ring spanner. David have 2x new bearings I brought of Trade Me 2.5 years ago, $40.00 the pair. ;) put a new set of adjustable shocks on the back, fitted the reworked driveshaft - new hanger bearing and uni's and rebalance, van back on the road, new single wheel diff just about ready for the fit, looks good with the toyo 15 x 60 x 295's on it. :D
New Shocks, set to soft ride, what a differance, happy boy
Reco Driveshaft.
New Hanger Bearing inplace / pressed on.
Re: Jumbo Diff ?
« Reply #16 on: March 02, 2012, 05:01:11 PM »
tube socket and rattle gun, take it down to a mechanic to rattle off for you
Re: Jumbo Diff ?
« Reply #17 on: March 02, 2012, 07:29:53 PM »
i couldnt get my pinion nut off.. i ended up using a 2metre long bar after lots of trying lots of different things.
Re: Jumbo Diff ?
« Reply #18 on: March 04, 2012, 04:25:38 AM »
I guess every ones experiences are different.
over the years Iv probably seen or done 10-15 without any dramas
Re: Jumbo Diff ?
« Reply #19 on: March 04, 2012, 10:14:04 AM »
The second one on your photos is very similar to my diff in my CF280 (1980).
More photos is here:
1. http://www.cf280.in.odessa.ua/img/archive/02/ (from photos IMG_1912.jpg)
2. http://www.cf280.in.odessa.ua/img/archive/03/ (from photos IMG_2237.jpg)
Abodator, what does you Mk 2 diff look like. Cheers
