  • Dot Guests: 363
Author Topic: Jumbo Diff ?  (Read 9514 times)
Jumbo Diff ?
« on: February 29, 2012, 11:02:19 AM »
Ok Guys, what is this for on the Jumbo diff, the plate is only welded on to the diff so only external, the unit itself is spring loaded and has a Hydraulic line attached to it. Need to know as the single wheel diff does not have this.  Cheers Bas
Ok could look it up in the Workshop Manual, but asking you guys is more fun. An I know how you love photo's
« Last Edit: February 29, 2012, 11:06:19 AM by Bas / NZ »
Re: Jumbo Diff ?
« Reply #1 on: February 29, 2012, 11:58:52 AM »
It looks like a form of stabiliser/sway/torsion bar set up.
But it doesnt seem thick enough compared to conventional ones.
Just a guess really
Re: Jumbo Diff ?
« Reply #2 on: February 29, 2012, 12:14:13 PM »
Just a guess, Is it a brake overload system? When the van bottoms out, the brakes go on to stop or slow you down
Offline Abodator
    • My CF280
Re: Jumbo Diff ?
« Reply #3 on: February 29, 2012, 12:22:34 PM »
« Last Edit: February 29, 2012, 12:39:32 PM by Abodator »
We are living in Ukraine, me and my vans: Vauxhall Bedford CF280 (1980) and Opel Bedford Blitz CF250 (1987) ;-)
Re: Jumbo Diff ?
« Reply #4 on: February 29, 2012, 01:40:55 PM »
Well I was way off the mark :)
Re: Jumbo Diff ?
« Reply #5 on: February 29, 2012, 03:36:44 PM »
OK thanks for that, had an idea it was related to that, cheers Abodator.
Ok one more please, what is the differance between these two diffs, is it just the year / model.......
This one has the chrome square back plate, my camper also runs this diff.
Back
front
Diff number 2, looks a lot more heavy duty, this is the one that will replace the duel wheel diff.
Back
Front
Re: Jumbo Diff ?
« Reply #6 on: February 29, 2012, 08:17:19 PM »
im fairly positive first one is early model swb diff, has 28 spline axels and 9inch drums, second is later model obviously more beefy. with 21 spliine axels and 10inch drums.
Offline Abodator
    • My CF280
Re: Jumbo Diff ?
« Reply #7 on: March 01, 2012, 03:36:35 AM »
The second one on your photos is very similar to my diff in my CF280 (1980).
More photos is here:
1. http://www.cf280.in.odessa.ua/img/archive/02/ (from photos IMG_1912.jpg)
2. http://www.cf280.in.odessa.ua/img/archive/03/ (from photos IMG_2237.jpg)
Re: Jumbo Diff ?
« Reply #8 on: March 01, 2012, 05:10:44 PM »
Anyone got a smart Idea to remove stuck axles, have used a slide hammer, no luck, guess I could heat up the bearing to free it, but may be not such a good Idea?
And yes thanks for the above info, will use the second diff as it would look better under a Jumbo, looks beefy.
Offline DocDamage
Re: Jumbo Diff ?
« Reply #9 on: March 01, 2012, 11:34:13 PM »
Try putting on a wheel with the nuts only on a few turns, then use the wheel like a slide hammer. The extra weight of the wheel will often do the trick.
I Have No Time For Impatient People
