  • Dot Guests: 373
Author Topic: Bedford Chassis Number Location?  (Read 20661 times)
Offline IWander
« on: February 28, 2012, 12:03:53 PM »
I have recently purchased a Bedford to convert into a motorhome and need to work out if I need any modifications/engineering certificates to get it registered in Victoria.
Can someone please help me first of all with the chassis number, its location, meaning or description of the vehicle and any other info you might think I can use.
Im told that the Firewall displays a number and that is the number to use. Mine in particular on that firewall is DJ475075, however when I rang Vicroads, the C.S.O. told me that the number is 16 characters long?
Now Im confused?
I would like to find out is if it is easier/cheaper to get it registered first, then convert it to a motorhome or do the whole thing at once?
Obviously if I have electrics, 240 volt that will need a certificate.... but I'd get that from the sparky and gas would be the same no doubt.
Engineering Certificates is going to be one of my biggest problems at that rate.
Does anyone know where I can get one, who from and maybe a ballpark on costs?
Having read posts on this thread (click on the blue letters to go there) and here I see there are quite a number of members that might have the right knowledge or are a good foundation to be able to help me out.
If anyone has any ideas about it I would very much appreciate your help.
Cheers. Mark.
Oh yeah the other thing I needed to know then, was engine sizes.
This one has a V8 and auto in it. So I need to find out if beddies came out with a V8 in them as standard or is that considered a modification?
Hmmm, yep thats a pretty full on request I've given you. Hope to hear back with your expertise.
Thanks everyone.
Re: Bedford Chassis Number Location?
« Reply #1 on: February 28, 2012, 01:46:54 PM »
The person at Vicroads was wrong, Chassis numbers have up to 17 characters, back in Bedford days, there was not that many.. The chassis number is the chassis number.
The cost of a engineer depends on which one you go to, contact vicroads websight and find one that is approved near you and talk to them with your plans before you start, and make shore your plan will be allowed by the time you finish. The rules are a mash at the moment, so listen to the engineer and vicroads, that way you won't guided in the wrong direction.
V8's are a modification, the thing to find out is, was it registed as a V8 previously, and hopfuly it was with vicroads and it still has the same engine number.
when you talk to vicroads, talk to some one in the modified vechicle section, get their name, and always try to talk to the same person. With a bit of luck, you'll get their direct line and that can save you up to an hour a phone call
  GOOD LUCK
« Reply #2 on: February 28, 2012, 08:34:04 PM »
G'day
Years ago the NSW RTA had a specification sheet showing that Bedford CF vans had been factory fitted with a 308 V8 and so didn't need an engineers report.
When I asked about I was told that 6 Bedford vans were fitted with a 308 for the Holden racing team. Because they were factory fitted that set the specification.
« Reply #3 on: February 28, 2012, 08:38:47 PM »
G'day
that would have been the days:)
« Reply #4 on: February 29, 2012, 05:40:54 AM »
They would of had to of had unique chassis numbers, would love to get my hands on an original one.
I wonder if any of them are still around
« Reply #5 on: February 29, 2012, 06:56:40 AM »
G'day
I had a CFS with a 308 T400 that I got a yellow bird for chirping too loudly. The 308 wasn't on the rego and when I took it to the RTA inspection station to get rid of the bird, the Inspector only wanted a weigh bridge ticket to pass the 308. He showed me the specification sheet that was in his book. I would have loved to get a copy.
« Reply #6 on: February 29, 2012, 10:25:38 AM »
so do we need an engineers cert to fit a v8?
if the van has disk brakes on front?
« Reply #7 on: February 29, 2012, 11:54:25 AM »
You will have to have an engineers cert to go for a piss soon. ;)
« Reply #8 on: February 29, 2012, 12:08:33 PM »
There was a van on ebay awhile back that said it was a Holden Racing Team factory V8, If I remember right, it was red and in QLD.
Not knowing any better, I thought they were full of shit ::) ::)
« Reply #9 on: February 29, 2012, 10:05:22 PM »
That is the $64 question! If it has a 308 the no you shouldn't.
I thought you already did. My eyes have been yellow for months. The local Engineer retired and nobody has stepped in.
I saw that one and thought it had been bought by a Bugarite. It probably was one of the factory vans.
