  • Dot Guests: 250
Author Topic: 350 chev diff shockies  (Read 6353 times)
Offline KGG86
« on: February 27, 2012, 03:17:20 PM »
Hello all.  I have a 350 chev diff on my van and I wanted to change all the shocks over what shocks would I use for the diff end .. The front end is still the original Bedford ones but just lil confused with the back end as they Are different to the standard Bedford ones .. Cheers kyle
Re: 350 chev diff shockies
« Reply #1 on: February 27, 2012, 05:09:25 PM »
fairly big job to change back to original springs on your van. id try get that engineered or make it look original and try slip it under the radar.
even if you did change it back to orig youd still need it to be engineered. because its been modded..
« Reply #2 on: February 27, 2012, 06:20:19 PM »
Ben looks like that lack of sleep is catching up with you ;D ;)
he is asking about shockies 8)
« Reply #3 on: February 27, 2012, 07:02:05 PM »
What exactly is a 350 chev diff?
Are we talking a 10 or 12 bolt that is often found behind a 350 chev? or some sort of motor that has been converted to operate as a diff?
In terms of shocks, you can go for anything from monroe or pedders upto bilstein or koni
Easiest way is to take the shocks out and take them into a suspension shop so they can match the height and connection types
« Reply #4 on: February 27, 2012, 07:23:46 PM »
Best Answer ;) ;) ;) ;) ;)
Offline KGG86
« Reply #5 on: February 27, 2012, 07:36:49 PM »
cheers heaps matte soudns like the best way to go about it
« Reply #6 on: February 28, 2012, 08:27:35 PM »
Ben looks like that lack of sleep is catching up with you Grin Wink
he is asking about shockies Cool
oh damn.. actually the opposite last few nights ive sleept 8 - 9 hours and feel groggy and discusting.. but going back 2 hours tonight so should be feeling better soon:)
