  • Dot Guests: 174
Author Topic: New Front end  (Read 11512 times)
Re: New Front end
« Reply #10 on: March 08, 2012, 04:49:14 PM »
the one your after are the sort after one. i got some but not too keen on letting them go
Re: New Front end
« Reply #11 on: March 08, 2012, 06:18:26 PM »
Worst case scenario, if i get off my ass and get some discs to machine down to my new stub axle size, my current stubs will be available. The have been machined to suit HQ/Z discs (which is bad) tho they've held up for likely 30 years or more ;) so should be ok in the short term while you locate a set of spares.
EDIT: wait, was your stub axle thicker, or Craig's? the thicker ones are the better option.. just machine your discs down further if it was Craig with the thicker stub axles.
What's wrong with yours?
« Last Edit: March 08, 2012, 06:20:57 PM by MaTTe »
Re: New Front end
« Reply #12 on: March 08, 2012, 09:55:25 PM »
he is after the thinner of the 2
Re: New Front end
« Reply #13 on: March 08, 2012, 09:58:23 PM »
so the thinner are more sought after? i'd rather the strength personally ;)
Re: New Front end
« Reply #14 on: March 08, 2012, 11:39:30 PM »
he needs the 72 stub axle
Re: New Front end
« Reply #15 on: March 09, 2012, 03:43:44 AM »
so the thinner are more sought after? i'd rather the strength personally Wink
the reason they are more sought after is you can grab the standard stub axel grab a standard hq disc rotor and get standard bearings (one bedford one xa ford) and it all fits together without machining anything.. when for the larger i havent seen anyone do the conversion without mods to something. whether it be disc brake rotor or stub axel.
Re: New Front end
« Reply #16 on: March 09, 2012, 06:40:42 AM »
over here the ticker one is the lwb one
Re: New Front end
« Reply #17 on: March 09, 2012, 06:53:23 AM »
you sure? thats weird cant understand why theyd be different? maybe i should pull a few more lwb hubs off to see if there all thinner axels here.
Offline crisis
Re: New Front end
« Reply #18 on: March 09, 2012, 02:52:52 PM »
G'day Matt, Craigs was thicker than mine hence the requirement to machine it done to fit.  Machining down to fit seems a hell of a job, so really hoping to find one ready to go?  are you saying you have some available or no?  Cheers
Who says a bedford can't drift??
Offline crisis
Re: New Front end
« Reply #19 on: March 09, 2012, 02:57:03 PM »
Hi all, Ben you sure you don't wanna sell one of your spare stubb axles?  m m maate!!  ha ha As far as I can tell, if properly maintained it is a life time article that should not need to be on the spares required list.  mine is floggerd out due to nil maintenance.  let me know cheers.
If not does anyone know how else to find one?  any UK sights or something of the like? Cheers
