  • Dot Guests: 226
Author Topic: lowering my bedford cf  (Read 41229 times)
Re: lowering my bedford cf
« Reply #30 on: November 22, 2012, 08:06:22 PM »
how much will the kits be????
Offline Rogerfied
« Reply #31 on: December 22, 2012, 11:35:03 PM »
Sorry for late reply, have been working away, still no confirmed price as more testing to be done, will supply cost, fitting instuctions and photos soon as I can.
 Disks and calipers are off a VT/VY Commodore and will still fit in 14" rims depending on offset, my 14" x 8" jellybeans fit fine, this can also be upgraded to the larger VZ disks and calipers but would require minimum 16" wheels. Front will also lower front of vehicle 35mm max. with no mods except to bolt these parts on. Will also be able to supply same equipment with standard ride height if required. Wheel stud change from Commodore (standard) to HQ or Ford will also be available
Offline Ratbox
  • probationary
« Reply #32 on: October 07, 2023, 07:59:56 PM »
big call but does anybody know if this went anywhere, did these kits Rogerfied was working on ever happen?
thanks
