  • Dot Guests: 343
Author Topic: 1972 Custom Camper Rebuild  (Read 5018 times)
Offline andrew_oc42
« on: February 18, 2012, 07:21:33 PM »
hey all, so here are a few pics of the beddy i picked up!
this restoration will be on a low budget, so it should be interesting!
pretty much, ripping the entire guts out of it and converting it to a band van.. polished floorboards, custom audio (i'm an audio engineer).. most likely ipad into the dash, quad subs ran in the floor, splits with hi/midrange mounted within the walls including full custom eq and the like!
i plan on keeping the fridge.. possibly upgrading it in the future (are these gas ran such as the gas stove cooker?
it's currently a black 202 3 speed.. runs really well although the gear shifter arm keeps poping out as the spring slides out.. is there an easy fix for this?
thought there is no point changing it just yet as she runs perfectly well!
future plans include making the roof automatic, and a complete interior / exterior haul all done by myself!
thanks guys! will keep updates coming if you're all keen!
andy.  ;D
Offline andrew_oc42
« Last Edit: February 18, 2012, 07:30:02 PM by andrew_oc42 »
Offline Banksx2
  • Willagee WA
Re: 1972 Custom Camper Rebuild
« Reply #2 on: February 18, 2012, 09:03:02 PM »
Actually looks pretty straight - get onto that gutter over the windscreen before it gets too far out of control!!
What is that on the engne cover??
Offline andrew_oc42
« Reply #3 on: February 18, 2012, 09:06:17 PM »
yeah thats the first thing i'm getting onto before summer is out. lucky the guttering is all surface rust, nothing has eaten through!
it's the bottom rear end corners that im worried about.. have to cut them out and shape them! should be fun..!
which pic mate? i dont know what your talking about!! thanks.
« Reply #4 on: February 18, 2012, 10:01:51 PM »
Carpet Gazza  ;D ;D
Offline andrew_oc42
« Reply #5 on: February 18, 2012, 10:04:20 PM »
all the carpet will be replaced! going to acoustically design the inside for such :)
« Reply #6 on: February 18, 2012, 11:39:45 PM »
Andrew
Your van is a "Autosleeper" like mine
« Last Edit: February 18, 2012, 11:44:21 PM by Warren »
