  • Dot Guests: 277
Author Topic: Front & rear wheel stud patterns are different  (Read 18188 times)
Offline tradsound
  • probationary
« on: February 07, 2012, 05:44:02 PM »
I bought my 78 SWB a while back with front holden disc brakes & a borg warner diff already moded.
My issue is i have a holden 5 stud pattern on my front wheels & a ford 5 stud pattern on my rear wheels.
Does anyone have any suggestions on how i could resolve this issue (within economic reason) so i have the same stud pattern all round & only have to carry one spare tyre? My presence is to stick with ford ones as the mags i like/use are a ford pattern & easy to come by.
Any advice would be much appreciated.
Joe
Re: Front & rear wheel stud patterns are different
« Reply #1 on: February 07, 2012, 05:48:28 PM »
are you allowed slotted mags there? ford and holden (hq-hz) are only half a hole out from each other.
Other option is to redrill front or back disc/axle
Offline Marky
« Reply #2 on: February 07, 2012, 08:01:04 PM »
Im with Busy...cheapest option..i reckon ..getting back drum redrilled to hq...
you have a good running gear set up..so no need to change diffs...
Creative Media Producer
« Reply #3 on: February 07, 2012, 11:30:24 PM »
I believe you can buy the HQ discs with ford stud patterns, that would be easier than redrilling the diff.
Some machining of the discs may be required as per the normal disc conversion, to allow for the bedford outer bearing though.
« Reply #4 on: February 08, 2012, 02:48:53 AM »
HOPPER STOPPERS
do that upgrade
new hq blank disks drilled to suit ford
cost about $300 with disks
« Reply #5 on: February 08, 2012, 05:47:57 AM »
Hq and ford discs are the same product, just different holes
« Reply #6 on: February 08, 2012, 06:31:30 AM »
have you thought of either slotting your spare or re drilling inbetween the holes on your spare i would think it would be the cheapest way. i had an intercepter wheel like this once. worked well.
Offline grunta13
« Reply #7 on: February 08, 2012, 12:14:28 PM »
My set up was the same got round it by putting a spacer on it that changed the patten to all the same but when i did that i was making up my flares so i made them fit  on the back
Offline Stangas
« Reply #8 on: May 15, 2012, 12:51:37 PM »
i have a question, as i have a similar issue
i have holden front and bedford rear...  how would i change the rear stud pattern around to holden?
-BED 253-
« Reply #9 on: May 15, 2012, 12:56:52 PM »
you bull both rear axles and re drill pattern to hq to match front and hubs as well.
