  • Dot Guests: 68
Author Topic: Front & rear wheel stud patterns are different  (Read 18173 times)
Re: Front & rear wheel stud patterns are different
« Reply #30 on: June 08, 2012, 08:34:58 PM »
I believe you can buy the HQ discs with ford stud patterns, that would be easier than redrilling the diff.
Some machining of the discs may be required as per the normal disc conversion, to allow for the bedford outer bearing though.
just finished re doing Borries brakes, HQ discs $58.00 @ so tomorrow have to go and get new brake line (broke the old refitting/buga) I
ll ask if I can get them redrilled or standards as ford stud patterns, let you all know ...
Offline russ
« Reply #31 on: July 19, 2012, 11:39:53 PM »
Hey I don't know if this thread is still running but all I would do is phone up Rocket in Sydney and order 1 multi fit rim made by Wheel Vintiques. I have holden stud patern on the front of my rod and ford on the rear. All rims are muli fit. Easy Peezy
Russ
Russ,  Keep on Van'in
