  • Dot Guests: 331
Author Topic: Clutch in three speed help!  (Read 5253 times)
Offline pandavan
« on: February 02, 2012, 11:59:29 PM »
Alright so I have a three speed and the 202 blah blah but my clutch smokes when driven aggressively (dont judge ;)  any way clutches on eBay for holdens etc are cheap is one of these what I need or does it need too be an actual Bedford specific clutch
Re: Clutch in three speed help!
« Reply #1 on: February 03, 2012, 12:10:57 AM »
sounds like its slipping bad.
be carefull buying things off ebay,
 its a outlet for a lot of new cheep crap parts,
 id buy a good quality holden  1 tonner clutch, to suit your motor.
remember you only get what you pay for,
 cheap isnt always better.
 you might go through 2 to 3 cheap ones compaired to 1 good quality one.
remember that a holden 1 tonner is a work vehicle and the 1 tonner clutch is tougher to handle heavy stuff, weight etc.
i always use them .
and always been happy withem.
« Last Edit: February 03, 2012, 12:20:18 AM by mty »
Offline pandavan
« Reply #2 on: February 03, 2012, 12:14:41 AM »
What year Holden one do I want the three speed is the reverse is top left first bottom left one  so I assume stock
« Reply #3 on: February 03, 2012, 12:19:18 AM »
just check with your local car parts supplier,
 but its usually from 1971 HQ  to 1984 WB holden 1 tonner.
ask the rep to show you the difference in quality between budget and heavy duty clutch plate, and pressure plates .
 you will notice the difference.
Offline pandavan
« Reply #4 on: February 03, 2012, 12:24:11 AM »
This is my first van I owned an fj40 before hand but picked up my van for 250 rusty body but pop top is perfect so I checker plated the rust sprayed it and already had offers over 1300 it's on gas but I'm pulling the system off as the tanks crap so I'll sell that on once clutch is done I'll be happy
« Reply #5 on: February 03, 2012, 12:31:59 AM »
Holden clutches are what you want not Bedford, unless you have one of the european/NZ motors.
We dont use the 1 tonner clutches in the race cars as they tend to become loose on the rivets prematurely. Though on a fairly standard motor this may not be an issue.
The clutch plates we have found to be the best are the Exedy, or funnily enough the Protex.
They are not expensive, just call up your local repco or a brake and clutch specialist.
Check the pressure plate, and make sure you sand the face of the flywheel and the face of the pressure plate heavily by hand with some 36grit, or 60 grit to roughen it up and give the clutch something to bite to.
While you're at it check the spigot bearing for wear, and if it does not need replacing, give it a light greasing
Offline pandavan
« Reply #6 on: February 03, 2012, 12:37:11 AM »
So rough up flywheel and check the what? Is it hard too change a clutch I'm nineteen so sorry for noob quest
« Reply #7 on: February 03, 2012, 12:44:05 AM »
its easy , specially on a beddy as they have higher grounnd clearance (unless u have a hoist) then its a snack.
dont breethe in the dust, wear a dust mask.
Offline pandavan
« Reply #8 on: February 03, 2012, 12:45:33 AM »
It has 2" lift blocks aswell
Offline pandavan
« Reply #9 on: February 03, 2012, 12:49:50 AM »
Is there anything I can do about the shifter it's small almost behind the seats and I hate it
