  • Dot Guests: 308
Author Topic: POOCHI HELLLLP!!!  (Read 6139 times)
Offline Poochimama
POOCHI HELLLLP!!!
« on: February 02, 2012, 08:08:23 PM »
OH NOOooooo...Drama back at Poochi station with her Muff machine,shit! :-[
Brother mechanic Steve needs help fellaz,...or i aint camping this week end,BOOooo!
OK, he said the 5th Cylinder has spark at the lead&the plug BUT when its running he can remove plug lead No-5 and it makes NO difference to Idol?????Rough.
Likes its got a dead cylinder? Hes stumped n needs help!
HELP,BUGGA HEADS TOGETHER,QUICK QUICK,
24hrs to fix this, i want to go camping!!  :'(
Quick reply ring Bro Steve: 04015-959-995
« Last Edit: February 02, 2012, 08:12:28 PM by Poochimama »
Re: POOCHI HELLLLP!!!
« Reply #1 on: February 02, 2012, 08:44:46 PM »
might be a dead plug?
do a compression test on that cylinder if its not a dead plug. plugs can show spark just slipped in the lead but can fail under compression.
is it back firing or coughing through the carby,
backfire = leaking exhurst valve.
if you put your hand flat over the tip of exhurst pipe (when cold) does it suck your hand onto it every 5 fires???
cough through carby = leaking inlet valve.
if its a leaking valve its possible to lap a valve without taking the head off,make sure the piston in that cyl is up top,  just put a fitting into that plug hole with 150psi pumping continuous into the cylinder,  remove the valve cletes and spring etc.
u can make a fitting by smashing the white porcilin off an old plug and welding a compressor fitting onto it.
take all precautins not to drop that valve into the cylinder, put a few laps of masking tape around the valve stem above the valve stem guide to hold the valve up.
u got 1 number 2 many in brother steve,s number 2,  ;)
just a few things i thought of instantly through same experiances
cheers marty
« Last Edit: February 02, 2012, 11:05:26 PM by mty »
« Reply #2 on: February 02, 2012, 09:04:06 PM »
Yeah could be a plug, swap it with another one and see if the symptoms move following the plug.
Then plug leads, one could be faulty.
Or points worn abit.
If none of that - compression test next, could be a burnt or sticking valve
Offline Poochimama
« Reply #3 on: February 02, 2012, 09:19:21 PM »
YEP, thanx marty n Waz<<lol!
Steve said ALL new plugs,cant swap leads as they dont quite reach but thr not new,
this 5th lead could be faulty hey?
OHHHH i hope its not a valve,steve frowned that and put his no good head on :-\
Dont have a compression tester,<<BUT IF ANY ONE HAS ROOM BRING IT SAT for me,lol..IF i make it??LOVE POOCHI,lol!
Cheers boyaz!  ;D
« Last Edit: February 02, 2012, 09:21:45 PM by Poochimama »
Offline rizzo
  • 666
« Reply #4 on: February 02, 2012, 09:41:05 PM »
this may help ya feel a bit better  Sensational Alex Harvey Band - Shake That Thing    so click and shake that thing rizzo
do it today there might not be a tomorrow
Offline Poochimama
« Reply #5 on: February 02, 2012, 10:00:02 PM »
That WAS kool song Riz,
i was shakin my fat booty to it, i was "Shakin dat thang" ;D,Lurve the harmonica in any music! Now its stcuk in my head,lol..shake dat thang!
Now back to stressing,lol,..work beddy worrrrk! :-[
« Reply #6 on: February 02, 2012, 10:53:24 PM »
could also be dissy cap
« Reply #7 on: February 02, 2012, 11:08:49 PM »
yep could be cap,
caps can get hairline  cracks and fill up with lead dust from the coil button and redirect the spark somewhere u dont want it to go.
thus not firing right on that cyl.
Offline rizzo
  • 666
« Reply #8 on: February 02, 2012, 11:14:33 PM »
Shelly is there any water in the cyl take plug out crank motor over and look for any shit coming out of the plug hole just poss that you may have blown a head gasket        here is another to get stuck in ya head           The Raveonettes - Love In A Trashcan   hope it all works out  rizzo
Offline Poochimama
« Reply #9 on: February 02, 2012, 11:54:26 PM »
OK,all yr theory's are getting WORSE now, Blown HEAD gasket...Noooooo,i feel sick! :-[
No song will cheer me up now Rizz,Noooo! ???
