  • Dot Guests: 338
Author Topic: wheel adapters  (Read 4007 times)
ehwagon64
wheel adapters
« on: January 29, 2012, 04:37:50 PM »
hi can any one tell me what wheel adapters i need as i have hq frontstud pattern and would like to change back end to put my mags on  i have 120.6 hq and 152.4 for beddie if this is correct where do i buy them from thanks ehwagon64
HI SORRY FOR CONFUSION I WANT TO CHANGE BEDFORD STUD PATTERN ON REAR END I WANT TO TAKE THIS TO  HQ STUD PATTERN AS I HAVE SET OF DRAGWAYS THAT R HQ STUD PATTERN AND LOOK EXCELLENT ON MY BLACK CF BEDFORD
« Last Edit: January 29, 2012, 04:55:26 PM by ehwagon64 »
Re: wheel adapters
« Reply #1 on: January 29, 2012, 04:52:49 PM »
mmmmmmmmmmm...........  interesting you wanna go back to bedford pattern  are you running discs on the front? if your rear end has been re-drilled you could remove and re-stud not sure wheel adapters are a safe move.
Re: wheel adapters
« Reply #2 on: January 29, 2012, 06:04:15 PM »
pull both rear axles out and hubs take them to an engineer and have them re-drilled to hq pattern then .
easy as
Re: wheel adapters
« Reply #3 on: January 29, 2012, 09:34:22 PM »
got mine from mr mag morley..
Offline jesus_is_alright
Re: wheel adapters
« Reply #4 on: January 31, 2012, 04:53:40 PM »
easy as
I did this on the front, had hub and drum re-drilled for hq.
One problem though, the centre bore hole (on the front at least) need to be about 91mm which is big. i Had to get my mags machined out to enlargen them from 76mm to 91mm. only had them machined to half the depth so i could still fit the centre caps on the front. See my gallery for details
-Aaron
Re: wheel adapters
« Reply #5 on: January 31, 2012, 11:55:27 PM »
easy as
if your dong this i would encourage you to fit falcon studs at the same time. larger and much stronger than hq studs..
