  • Dot Guests: 240
Author Topic: need advice re: diff PLEEEEEEEASE!!!  (Read 4773 times)
dannynogood
« on: January 19, 2012, 10:03:36 AM »
If any one has some advice i would really appreciate it!
can i use the diff assembly from a 78 (swb) beddie in a 79 (swb) beddie. Should it, essentially, just bolt in?
My poor beddie is just sitting there...... waiting
Offline Jeff
Re: need advice re: diff PLEEEEEEEASE!!!
« Reply #1 on: January 19, 2012, 06:48:06 PM »
Shouldn't be any problem at all as long as they are both Bedford diffs,.
People like us swap them for other makes to get more friendly ratios, and that can create fitting difficulties.
Funny old life.
Offline LS120
« Reply #2 on: January 20, 2012, 04:57:03 AM »
if it has the same spring setup & uses the same drive shaft connection and Drum size (9" or 10") then 99% yes you can use it..
Offline LS120
« Reply #3 on: January 20, 2012, 05:00:11 AM »
oh & if anyone wants a good Bedford standard Crowwheel & pinion i have one to give away.. was a good runner no wihines or noise when it was in the diff but taken out to replace with cresta center a while ago.. we are moving house this weekend & some stuff has to go as not as much room (small 1car garage)
