  • Dot Guests: 286
Author Topic: Interior Roof Linings  (Read 18794 times)
Re: Interior Roof Linings
« Reply #30 on: January 20, 2012, 12:38:54 PM »
Garry, do you recal the price on the ply (Bendy) at all.......... Cheers
« Reply #31 on: January 20, 2012, 09:31:33 PM »
OK I've got an idea for you but it's messy, get a can of that spray expanding foam and spray it in small sections to the underside of the roof, when all done and dry shape to desired style then get some cheese cloth material and stick it to the underside of the roof you might have to do it in small sections so it doesn't fall down now mix up some resin and do the same thing with that, once it has dried carefully prize down the resin/cheesecloth liner the side that touched the roof scrape off the foam that is stuck to it then put on a couple of layers of fibreglass and resin to strenghen it once set you now have your roof lining, the inside can be covered with what ever you want then you can glue it to the inside of your van but remember to remove that dry spray foam first thats stuck to the inside of the van
Offline Sundownernz
« Reply #32 on: February 01, 2012, 09:33:04 AM »
Hey Bas,
Not sure what the cost was but was similar to a sheet of standard ply. Bought mine about 10 years ago. Give them a call and they'll sort you out.
Garry.
« Reply #33 on: February 01, 2012, 10:31:27 AM »
basically what i described but it would be a nightmare trying to work upside down, better getting a full roof cut and turning it upside down then weld some legs on it like a table, gravity is your friend, :)
then check out the utube clip earlier in this thread on page 1.,
« Reply #34 on: February 01, 2012, 12:34:17 PM »
what about if we used a rotisserie and turned a van upside down? any reason why you couldn't do that? could save cutting a roof off a van.
« Reply #35 on: February 01, 2012, 06:49:39 PM »
Good idea Ben
« Reply #36 on: February 02, 2012, 05:53:23 PM »
George, I can fabricate one up for you if you like......or just call me for more info....Dano +61 448993742
« Reply #37 on: February 11, 2012, 04:44:55 PM »
i forget who asked for some ideas on interior linings ...i we used synthectic boat or thin trunk liner over all the surfaces in the back..got a cylinder of sray glue that comes with  own spray gun...used car carpet on floor & wheel arches..that come our easliy when we need to carry messy stuff.
tried to load pics here but uploader full so pics in my gallery on page five under wendyh  or on the left if still thr...
« Reply #38 on: February 11, 2012, 08:35:33 PM »
Looks good, but don't think the sound  / noise reduction would be the great ???
« Reply #39 on: February 11, 2012, 09:10:23 PM »
What noise when u got a good stero system in place and functioning perfectly  ;D... hey its a beddie you gotta love em as the maker intended them to be.....
