  • Dot Guests: 280
Author Topic: FRONT SHOCKS CF SWB..  (Read 14534 times)
« on: November 19, 2011, 04:23:11 PM »
anyone know where to get them from in w.a??
repco doesnt even have a listing for bedfords..
thanks
Offline LS120
Re: FRONT SHOCKS CF SWB..
« Reply #1 on: November 19, 2011, 07:11:01 PM »
pedders do beddy shocks..
Offline cfjeff
« Reply #2 on: November 19, 2011, 07:19:28 PM »
if stuck see if they have a listing for FC holden, is the same mounting and length. Went to get some for my beddie recently and they were out of bedford but the guy said FC holden was the same and they had them in stock.
Just customize it!
« Reply #3 on: November 19, 2011, 10:57:01 PM »
are you sure..
fc dont look like this i have fitted them before..
fc shocks???
« Last Edit: November 19, 2011, 11:16:42 PM by vintageholden »
« Reply #4 on: November 20, 2011, 04:17:44 AM »
They'll fit. I just replaced mine all round with KYBs and the front looked just like that.
I'm referring to the top photo.
« Reply #5 on: November 20, 2011, 10:30:19 AM »
i know..
top photo is bedford .
bottom is fc..
was told fc fit????
Offline cfjeff
« Reply #6 on: November 20, 2011, 06:19:23 PM »
Ive still got the box in the shed i'll check what it says on the box, the guy at the shock shop I bought them from said they were fc holden, and get back to you
Just customize it!
Offline cfjeff
« Reply #7 on: November 20, 2011, 06:29:56 PM »
just checked box, typical dont state what its off just a code, they are monroe gt gas shocks code 15-0096. and the ones I got looked the same as the beddy ones except they didn't have the dust sleeve over the shock only the chrome shaft. which I was advised was you don't need. Anyhow you could try your retailer on that monroe code to see what they look like if they have in stock.
Cheers Jeff
Just customize it!
« Reply #8 on: November 20, 2011, 08:15:49 PM »
i know..
bottom is fc..
was told fc fit?Huh
i didnt realize until now but i have seen several vans fitted with fc schocks inc one of my own. if they are the same length and all that. Mezzmo (on here) has those fc fitted. i just didnt realize they were from a FC i thought they must have been another bedford shocker..
they do mount slightly different thou. take the plates off the bottom and use the round end on the bottem and i recon you would have to rheem out the bottom wishbone slightly too to bolt it up..
thanks for the info cfjeff.. very helpful!!
Offline JOE RYAN
« Reply #9 on: November 20, 2011, 09:43:35 PM »
I have the bottom ones on my 75 SWB
Joe
