  • Dot Guests: 268
Author Topic: WTB: Driver's door lock mechanism (with key) and front mudflaps.  (Read 3382 times)
AdamAdeane
« on: November 14, 2011, 01:57:24 PM »
As above. I'm based in Taupo, New Zealand.
Re: WTB: Driver's door lock mechanism (with key) and front mudflaps.
« Reply #1 on: November 14, 2011, 02:27:55 PM »
The universal mudflaps from Repco or Supercheap should fit fine. That's what I used on mine although I had to alter the bracket a wee bit.
« Reply #2 on: November 14, 2011, 05:31:25 PM »
Are you after the handle or door catch?
If its the handle (if lock is stuffed), you can use the barrel out of any other bedford door and just get it recoded to suit your keys. I had a whole set done (had no keys and all were different) about a year ago for $250, 2 fronts, side and back door.
If you can't find a barrel I have one but no key,
« Reply #3 on: November 15, 2011, 05:09:55 AM »
Strange, I have a key here, that fits all Bedford doors, opens both my vans, and a couple of other Bedfords I have used it on, looks are not worn, because both keys form my Bedfords, don't fit each other. This is a very handy key ;) Not sure what it was used for in the past, some car / van I had.
« Reply #4 on: November 15, 2011, 10:58:57 AM »
i dont like standard locks they are so easy to get around.
try this.. keyless entry kit for $45 on ebay. get rid of your door lock knobs.. mount a plate in the door to stop theives using a coat hanger to pull the mech up and there not much else they can do.. except smash your window.
you can use the actuators on all doors also inc barn doors/ cargo doors. will take some fiddling with to fit but much more secure in my opnion.
http://www.ebay.com.au/itm/SPY-Universal-Remote-Central-Locking-Kit-Keyless-Entry-/380243347900?pt=AU_Car_Parts_Accessories&hash=item58884509bc
Offline jimmyfreak
« Reply #5 on: November 16, 2011, 04:41:30 PM »
Unless you jump in the pool fully clothed aye ben ::)
« Reply #6 on: November 17, 2011, 11:15:42 AM »
ay:(
