  • Dot Guests: 313
Author Topic: ?? Fibreglass ??  (Read 7133 times)
Offline Sweet Shock
?? Fibreglass ??
« on: November 04, 2011, 06:54:43 PM »
Hi all I want to attach my shovel  front. What is the best  fibreglass to use , brand and type, Got any tips, Ben this seems to be your field of expertise.  Thanx pete
Re: ?? Fibreglass ??
« Reply #1 on: November 04, 2011, 07:00:53 PM »
Offline wazzah
« Reply #2 on: November 05, 2011, 09:03:47 AM »
 This way involves no glass matting at all, you get epoxy resin mix with the harder and then mix it with micro fibre (adhesive filler) there are different grades of this powder from maximum adhesive to fairing and sanding, of course you use the max-adhesive. You then spread this over the bare metal guard and then place the flare on top of it and screw or pot rivet it down, allow to harden then grind the outside of the flare up and apply another lay over the top, apply as much as possible to form the shape needed thus giving it more strength, sand and apply a filler over the top to finish off. In both cases it is best to pre fit the flare on the guard and drill the holes etc so it is easy to reline up, also it is a good idea to leave the screws or rivets in and just grind the top a little before you glass over the top or use the max-adhesive filler, do not use normal filler to cover the screws as they will only come though in time.
One other step that can be taken to help bond it to the metal guard is to drill the odd hole in the guard so the glass or adhesive filler can spread though the hole and make it even hold better, as most vans have a double skin you can't see this so there's no problems.
If you need the code names for the adhesive filler let me know as I'm sure Fibre Glass International has it in Aussie.
This sounds like the best way,but can you get the stuff here in oz? and were do you get it? wouldnt mind giving it a try this way as not to good with fiberglass..haha
thanks
wazzah
build it and they will come
« Reply #3 on: November 05, 2011, 09:20:45 AM »
Will post a picture today of the product, yes you can get it in OZ. Bas
« Reply #4 on: November 05, 2011, 10:34:28 AM »
yeh ive used microfibres and epoxy and its real good stuff. yes you can get it at any fibreglass supply shop. pete there is a shop in geelong. ive never been there and cantremember the name of it but do a search in yellow pages itll show up.
Offline Sweet Shock
« Reply #5 on: November 05, 2011, 07:06:59 PM »
Thanx boys I had a look at the link and sounds reasonbly straight forward and a pic would be great,
Offline Sweet Shock
« Reply #6 on: November 05, 2011, 07:10:54 PM »
I think its this place Ben
Martini Fibreglass Industries Pty Ltd
23 Fernleigh Street, Newtown, Victoria, Australia 3220
« Reply #7 on: November 05, 2011, 07:21:34 PM »
Will load some up Sunday morning. Bas
« Reply #8 on: November 06, 2011, 02:10:38 PM »
yeh that rings a bell ay pete:) also chat to able.. he has done the whole microfibres thing.
« Reply #9 on: November 07, 2011, 04:07:40 PM »
Here are the photos of the micofibre you use.
