  • Dot Guests: 309
Author Topic: ENGINE HELP!  (Read 16799 times)
Offline Poochimama
Re: ENGINE HELP!
« Reply #30 on: October 14, 2011, 05:09:05 PM »
Hi Reid,
Thanx for yr thoughts, just asked steve and he said its all oiled up nicely,he made sure of all that whn putting it back together!
He thought he FINALLY found the problem just b4,the rotary botton thingy was very small and felt it wasnt hitting the sides to spark properly, just replaced it with a new proper size one and now its backfiring even worse,like gun shot noises,things are getting worse,we cant even drive it to a tune up guy its so bad now,ARRRRRRRGH ..just want my poor brother to have some peace with this bloody bedford,its getting me down now seeing him so stressed for the last 10days 10hrs a day hes tryn to work whats wrong!:(
Thanku for yr suggestion, weve eliminated everyones suggestions so far as we have tried them all,except for the W.A holden guy...Steves  yet to do what he said it may be, i just want it solved for my bro sanity,poor thing!
Thanku
Offline cfjeff
Re: ENGINE HELP!
« Reply #31 on: October 14, 2011, 06:19:41 PM »
just another thought, it is a blue 202 motor and not a black 202 motor that came out in the VK commodores painted blue, the reason is the black motors had that knock sensor it thingy in  the bell housing and they were notorious for causing problems with tuning.
Cheers Jeff
Just customize it!
Re: ENGINE HELP!
« Reply #32 on: October 14, 2011, 07:23:00 PM »
Are you sure youve got the fireing order right for the direction the disi turns
Offline Poochimama
Re: ENGINE HELP!
« Reply #33 on: October 14, 2011, 08:11:55 PM »
YEP, steve said!
Re: ENGINE HELP!
« Reply #34 on: October 14, 2011, 08:36:05 PM »
Im sorry I surgesterd that but Iv done it wrong & timeing is very important if youve had the disi out its real easy to get one tooth out & it takes some head scratching to work out what youve done wrong
Offline jimmyfreak
Re: ENGINE HELP!
« Reply #35 on: October 14, 2011, 09:00:31 PM »
hey pooch thanks for doing a good sale on the 186 with my old man. Hope the dosh helps u out. I am praying for u and ur nightmare situation...  :-[  :-[
i did that the other day reid, put 2 & 3the wrong way round on a 4 cylnder. Couldnt figure out why air was blowing out the top of the carby....whoops....bu then again i am still a newb...
« Last Edit: October 14, 2011, 09:04:57 PM by jimmyfreak »
Offline Poochimama
Re: ENGINE HELP!
« Reply #36 on: October 14, 2011, 09:30:48 PM »
REID,
DONT be silly, we are OPEN to ANY and every  suggestion, one of us HAS to hit the bloody jackpot soon.PLEASE,lol!
Brainstorm Beddy Boys, keep em coming& the winner get a willi wonka gold ticket,ok, make it a box of chocolates u have to share with ME,..OHhhh OK and some beers THENNNN  ;D
Offline Poochimama
Re: ENGINE HELP!
« Reply #37 on: October 14, 2011, 09:37:25 PM »
No probs Jim, Tonys a kool ol hoon he told me,lol!
YES all money i raised goes towards Stevespaddedcell.com.au,
Thanku  ;D
Offline JOE RYAN
Re: ENGINE HELP!
« Reply #38 on: October 14, 2011, 10:23:38 PM »
Did you use the manifold off the 186, someone on this site once said the 202 manifold was different to the 186 one, just a idea to consider
Joe
Re: ENGINE HELP!
« Reply #39 on: October 15, 2011, 12:39:55 AM »
the harmonic ballancer center hasnt spun a bit inside the outer and giving you a out of line timimg mark has it?
sometimes the dissy caps can have hairline cracks that fill up with lead dust from the center of the cap coil contact causing spark to track across the cap to wrong sparkplug leads as well.( this will cause backfiring as the exhurst or inlet valves on the offending cylinders will still be open.)
carberator floats can leak and fill up with fuel and sink also causing dramas,
cheers marty
« Last Edit: October 15, 2011, 12:47:32 AM by mty »
