  • Dot Guests: 314
Author Topic: ENGINE HELP!  (Read 16790 times)
Offline Poochimama
ENGINE HELP!
« on: October 11, 2011, 05:06:28 PM »
Hello agaaaaain my bugga buddys,
Senario:
We bought the 202blue engine that puuured in my mates commodore.
Removed the original 186red from the beddy,put the 202inn.
Now its runs rough,running rich/petrol smoke.
My poor brother talks to the carbi mob,they said its not the engine if it was all good running before ,its the carbi,bring it down for a reco,picked up the reco carbi $$$, fitted and timed it at home,STILL running shit? >:( It was to rough to drive it to the carbi mob,they test it on another engine there.
My brothers tryn to think what 186motor /leads etc he used on the 202 now inn,hes thinkn maybe one of the leads etc are not compatible? Hes says its still getting to much petrol?
Also only thing my brother did when he took the head off the 202 motor before putting it into the Beddy is  remove the sludge inside,cleaned it properly.
SO...any ideas whats gone wrong Beddy boys??? ???
Thanku for always helping me,
shell
Re: ENGINE HELP!
« Reply #1 on: October 11, 2011, 05:25:40 PM »
MMmmm....Leaking inlet manifold gasket? Crack in manifold itself?? :-\ :-\
Re: ENGINE HELP!
« Reply #2 on: October 11, 2011, 05:31:33 PM »
Did you use the same carby/manifold off the blue202? or the stuff off the 186?
Timing, vacum hose to advance unit, voltage to coil (blue 202 runs elec ignition which from memory requires more volts)
Holding your tongue the wrong way - BUGAd if I know :)
Offline Poochimama
Re: ENGINE HELP!
« Reply #3 on: October 11, 2011, 06:22:54 PM »
YES,the carbi's from the 202motor,mates commodore!
And warren...hes biting his tongue hard now..
he is NOT HAPPPPPY JANNNNN! :-[
Offline cfjeff
Re: ENGINE HELP!
« Reply #4 on: October 11, 2011, 07:26:53 PM »
Gidday, to test for leaking manifold get a can of engine start or similar and while running spray around the manifolds if the engine picks up then this is where your leak is. Another thing to check is the gasket between the inlet and outlet manifolds, from memory if these leak it can cause it to run rough. One of our members put a blue 3.3 motor out of a commodore into his cf  bedford truck and had this problem and found it was the link between the inlet and outlet manifolds, from memory he said it was a bugger to seal.
Cheers Jeff
Just customize it!
Offline Poochimama
Re: ENGINE HELP!
« Reply #5 on: October 11, 2011, 08:50:09 PM »
THANKU for helping ;D
Warren,he said its still a 12volt battery so hes not sure what u are sayn?
And yes, he said thanx...he will check the manifold tomorrow,
Thanx again,
shell
Re: ENGINE HELP!
« Reply #6 on: October 11, 2011, 09:11:20 PM »
blue motor dizzys nead 12volts at the coil...
you have to fit a relay
do a search..for fitting blue dizzy etc...
http://gallery.oldholden.com/ReaperHR/HRWorkguides/EngineIgnition/Blue_Electronic_Ignition/
« Last Edit: October 11, 2011, 09:14:58 PM by vintageholden »
Offline Poochimama
Re: ENGINE HELP!
« Reply #7 on: October 11, 2011, 11:30:21 PM »
OH,ok..ill tell him,
and thanx for the link! ;D
Offline jimmyfreak
Re: ENGINE HELP!
« Reply #8 on: October 12, 2011, 06:45:52 AM »
Man hope u get it working...thats just annoying...
just on a side note pooch, what did u end up doing with the 186 you took out? was it stuffed, just curious, as i know someone who could make use of it...
Offline Poochimama
Re: ENGINE HELP!
« Reply #9 on: October 12, 2011, 10:59:40 AM »
YEAH it IS sooooo frustrating, i feel for my brother as hes done so much work on it for me  :-\
Yep steve said sell the lot:
186Red Motor originally in beddy $100 It went fine from Qld to Melb,but steve said he hasnt had time to take head of and see condition of it!
Pair extractors for 186 $50-
Also a warn 202 other motor for parts $50
2 x 202 trimatics $50ea
He was going to put the lot on ebay,but if u guys want them?
Live near the Tulla airport.
Steve: 0415-950-995
« Last Edit: October 12, 2011, 11:54:54 AM by Poochimama »
