  • Dot Guests: 317
Author Topic: what have you been up to  (Read 35549 times)
Re: what have you been up to
« Reply #70 on: October 29, 2012, 10:00:40 PM »
done, just electrics, tailshafts, exhausts engine cover to do.......
« Reply #71 on: October 30, 2012, 05:05:19 AM »
Don't forget the windows too Dano or it might get a bit breezy.
« Reply #72 on: November 03, 2012, 10:22:25 AM »
stage 1.5 done. rear wall and ceiling over bed area finished
« Reply #73 on: November 03, 2012, 05:03:19 PM »
When you coming over to do mine hotrod? :)
I actually did some work on my custom van last couple of days (and it felt awesome), been making the water channels that go through the front guards as well as welding in the windscreen frame.
Hopefully the weather lets me do some more tomorrow
« Reply #74 on: November 04, 2012, 01:57:59 PM »
i have been doing.......................................................... f***all!!
« Reply #75 on: November 04, 2012, 11:06:13 PM »
Same as last month hey Skipp :)
Offline Brendeni
« Reply #76 on: November 05, 2012, 08:48:33 AM »
Got a bit done this weekend. New/old ZB Fairlane tail lghts. Updated a dated jaguar dash with carbon fibre look vinyl.
Brendon
Offline Brendeni
Brendon
« Reply #78 on: November 05, 2012, 09:47:19 AM »
Tail lights look fantasic, were they just a straight bolt up? Keep up the good work!
Offline Brendeni
« Reply #79 on: November 05, 2012, 10:30:01 AM »
Hi Mezzemo
Some cutting but not much. Just cut the corners and bent back the metal a bit. Then drilled some holes so it could be fasten to the van. I actually got these from aussy. Ben was kind enough to post it with some flares that i got off him. They look so much more beefier( if that's a word) that the standard lights. Dont really like the LED type lights. Looks a bit to modern. It comes with the indicator wired. All you need to do, is use the double bulb for the park and brake lights which fit in the ZB holder without any issues.
Brendon
