  • Dot Guests: 349
Author Topic: BEDFORD CF DIFF...SWB....PERTH..  (Read 7288 times)
Offline LS120
Re: BEDFORD CF DIFF...SWB....PERTH..
« Reply #10 on: November 01, 2011, 02:40:41 PM »
wanted to keep the wheels i had.. going to look at hho again to get more mpg over Xmas time.. have all the new info update specs..
Offline mbasinski
« Reply #11 on: November 01, 2011, 08:16:16 PM »
http://perth.gumtree.com.au/c-Cars-Vehicles-Motorbikes-Parts-parts-accessories-engine-engine-parts-transmission-DIFF-W0QQAdIdZ310057184
or should i just buy this. would i need 2 do anyhing 2 this 2 fit or is everything there and where it should be looks like the diff i already have
« Reply #12 on: November 01, 2011, 09:31:14 PM »
add says its got no center in it.
Offline mbasinski
« Reply #13 on: November 01, 2011, 11:08:25 PM »
i thought that was the break pads and stuff
« Reply #14 on: November 02, 2011, 01:05:52 AM »
thats whats in mine..
can get for about $100-$200 in the quokka..with center..
Offline mbasinski
« Reply #15 on: November 13, 2011, 07:47:06 PM »
do i take off my back end with or without the leaf springs. wats easyr. doing now
« Reply #16 on: November 13, 2011, 07:54:06 PM »
diff is under the leaf spring so leave the leafs there..
what diff did you end up getting
i have one for sale now.$150
from a 1 tonner 3.55 ratio
« Reply #17 on: November 13, 2011, 08:17:44 PM »
You will need 2 axle stands and a good jack
1. undo the lower shock mount bushes
2.take the break hub off and release the handbrake cable & break line on Y side
3. undo the uni joint that holds the tail shaft (4bolts)
4.undo the 4 nuts on top off the big square flat plates that are attached to the Ubolts
5. make sure you place a good jack under the center off the diff
6.Jack the van up and place the axle stand in Front off the diff under the springs
7. Gently lower the van and the diff will separate from the spring locating point
8.if your axle stands were high enough just wheel the housing out.
Have I missed anything?
Daves will have his new diff in on Tuesday feel free to come over for a brew if you want to have a gander.
remember safety 1st, that beautiful contract you have with your missus is null and void if your Flat  ;D
