  • Dot Guests: 381
Author Topic: speedo  (Read 6117 times)
Re: speedo
« Reply #10 on: September 20, 2011, 11:01:24 PM »
rizzo,
like Jeff n petrolhead said  the usual reason the speedo,s jomp is because you will probebly have a kink in the inner cable or sometimes they have a fray.
pull the innercable  out and check for a kink/bend.
i also put a post in here somwhere about the adjustment on the speedo gauge, maybe someone could locate it n bump it to the front?
 cheers marty
« Last Edit: September 20, 2011, 11:46:31 PM by mty »
Offline rizzo
  • 666
Re: speedo
« Reply #11 on: September 26, 2011, 03:45:42 PM »
Hi there guys and gals found the problem plastic gearbox gear worn and teeth broken off will get one at rare spares ? thanks for all your input buga is the place to be rizzo out
do it today there might not be a tomorrow
