  • Dot Guests: 287
Author Topic: hhhmmmm....  (Read 12796 times)
Re: hhhmmmm....
« Reply #20 on: August 24, 2011, 12:19:46 PM »
I have been looking at autoloc, but the one thing that keeps coming back is, that you need a heavy duty set-up to handle the weight of the glass and winders. For now i am still looking around  for something heavy duty, after all, the last thing you want is to set it all up have it working, then have it burn out because the gear was under powered. I'm sure there is something out there.
the weight should not be a problem , the glass from a 56 Effie is heaver and the rod guys don't seem to have a problem.
Re: hhhmmmm....
« Reply #21 on: August 24, 2011, 06:37:53 PM »
late model = 2 years max
The little jap trucks, canter and others I think have semi straight glass.
The other thing you have to remember is where the motor sits for the unit, the first electric window unit I used was right length etc but when I mounted it I found the motor was hard on the outer door skin and actually under strain when window was right up, second stuck out to far the other way so third time was a motor in the middle.
After market kit is probably the best bet
Always4ward
Re: hhhmmmm....
« Reply #22 on: August 25, 2011, 01:55:37 AM »
try hiace i work with cabbies at melbourne airport a lot of the maxi taxis have electric windows and im 99% sure the glass is straight, and who knows being a van the unit may fit better
Re: hhhmmmm....
« Reply #23 on: August 25, 2011, 08:36:51 AM »
Craig. you need to come up for a coffee!   re power windows.
Re: hhhmmmm....
« Reply #24 on: August 25, 2011, 08:52:50 AM »
me? shit....no  I started the thread on a fuel cap then tried to start the power window thread so I could have my fuel cap thread back but no one took the hint lol
or do you need a hand?
Re: hhhmmmm....
« Reply #25 on: August 25, 2011, 09:49:49 AM »
Can i come to? Craig?
Re: hhhmmmm....
« Reply #26 on: August 25, 2011, 10:49:14 AM »
hell yer when are we going
Offline Banksx2
  • Willagee WA
Re: hhhmmmm....
« Reply #27 on: August 25, 2011, 08:13:41 PM »
Me too if it's OK - I'll bring a fuel cap AND a window-winder-handle... ;D
Offline Banksx2
  • Willagee WA
Re: hhhmmmm....
« Reply #28 on: August 25, 2011, 08:17:48 PM »
And beer to go with the coffee
Re: hhhmmmm....
« Reply #29 on: August 25, 2011, 08:28:56 PM »
so danno ? when do you want all of us  ;D ;D ;D
