  • Dot Guests: 287
Author Topic: hhhmmmm....  (Read 12796 times)
Re: hhhmmmm....
« Reply #10 on: August 22, 2011, 12:54:31 PM »
If it wont go in because its to big, try going swimming in winter, it should shrink and fit. lol  ;D ;D ;D ;D
SHRINK OR DISAPEAR, NO PROBLEMS THEN  ;)
BUT PLEASE TELL US MORE, UNIT LOOKS LIKE IT WOULD BE A GOOD SET UP............
Re: hhhmmmm....
« Reply #11 on: August 22, 2011, 07:48:04 PM »
its too big to fit ...the locking bit won't actually go in the hole..mines a 77 swb and I have heard there is two sizes so I guess I have the other size
yes I agree, tried fitting the shorty to the longy but two different sized holes, lwb bigger...... and yes I AM LOOKING FOR A FILLER CAP if anyone has one, cheers.
Offline KGG86
Re: hhhmmmm....
« Reply #12 on: August 22, 2011, 07:55:06 PM »
so dano , your saying you need to smaller one for the swb vans?? do u kno which autoloc power window is the small one??
Re: hhhmmmm....
« Reply #13 on: August 22, 2011, 10:24:14 PM »
I think hes talking about the fuel filler cap
Re: hhhmmmm....
« Reply #14 on: August 23, 2011, 06:08:50 AM »
What are the elec windows units like then, anyone know. ???
Re: hhhmmmm....
« Reply #15 on: August 23, 2011, 08:42:19 AM »
I have been looking at autoloc, but the one thing that keeps coming back is, that you need a heavy duty set-up to handle the weight of the glass and winders. For now i am still looking around  for something heavy duty, after all, the last thing you want is to set it all up have it working, then have it burn out because the gear was under powered. I'm sure there is something out there.
Offline likemagic
Re: hhhmmmm....
« Reply #16 on: August 23, 2011, 03:51:55 PM »
i have a couple of 74 jag doors with electric winders and that i am  going to look at adapting. still got to pull every thing to bits to see how it looks. most of the modern stuff is bit light weight, have to keep spraying the tracks with silicon to stop the motors burning out when they are more than 5yrs old.
Lots of ideas - shed full of parts - need more time
Maurice
1980 CF230, with 2.3l, toyota 5 speed, toyota windom seats, and of course the rust
Re: hhhmmmm....
« Reply #17 on: August 23, 2011, 06:40:58 PM »
In my custom van I used some jap ones - of course I did it the hard way.
The biggest problem with the jap ones is they are designed for curved glass, the CF has flat glass ... I straightened out the runner and as I had a mate in the glass business didn't worry about the mounting of it. Because of the roof chop I had to get new windows made so got them to drill them at the same time, they are toughened so are strong but wouldn't do it this way again.
pros of this method:
gave me electric windows
cons of this method:
straightening out the rails causing the wire to become loose (it can be tightened) but the biggest problem (if you can remember what you got it out of) is having to straighten another one if it ever crapped out and it wasn't a 5min job
drilling the glass, doesn't allow for much adjustment of the window (not that you should need much but can be adjusted on mounts) and the cost if you don't have a mate in the business.
Isn't a 5 min job
makes you swear and throw things :D
There is another universal kit on the market, is like autoloc's but has been around for yonks, a lot of hot rodders used them. I don't think it had a name, just universal electric window kit.
Re: hhhmmmm....
« Reply #18 on: August 23, 2011, 11:03:28 PM »
Busy, i went the same route ;)
But i used BA falcon motors, flattened out the runners, i CAN however swap the motors over fairly easily if one burns out or breaks the wire, and my wire is still tight, although mounting the motor was difficult as the motor used to fit within the curve, so end result was a butchered door..
If i were paying for the BA window motors i'd have gone with the autoloc kit as it looks nicer and well finished, but since i already had the motors i decided to get tricky..
by the way, electric windows rule.
Johnbongjovi, if you know anyone with a lwb near by, can you try the cap in their van? i like the look of my petrol cap, but i like the fact that this one locks
Re: hhhmmmm....
« Reply #19 on: August 24, 2011, 09:07:31 AM »
The problem i have with using a jap, ford or holden is this, back in the 90s i grafted in a set of VH commodore handles, nice and light, no problem with central locking system. But with the windows, you need to remember what car you got it from, and as stated above there is some work with the original install, then the challenge of getting that part again, unless you buy a spare set, where as if you can get an aftermarket kit, chances are you can get the parts in the future, also you are buying new and not secondhand with no garrantee of wear and tear.
Is there a late model car or truck with flat glass that you could use. What i would do there is buy the gear new and install the bits, being late model should be around for at least 10yrs, light weight and new parts, + being for flat glass less work to install ? maybe someone knows.
