  • Dot Guests: 377
Author Topic: Steering column  (Read 9384 times)
Offline Sweet Shock
Steering column
« on: July 29, 2011, 12:00:09 PM »
Iam about to change the bearings in my steering column. Does any one no where to get the bearings from and how hard this job is, are there any suprises             thanx pete
Offline likemagic
Re: Steering column
« Reply #1 on: July 29, 2011, 05:34:02 PM »
north island, south island, west island or tazzie??
1980 CF230, with 2.3l, toyota 5 speed, toyota windom seats, and of course the rust
Offline Sweet Shock
Re: Steering column
« Reply #2 on: July 29, 2011, 07:35:46 PM »
Close! Geelong
Re: Steering column
« Reply #3 on: July 29, 2011, 07:41:20 PM »
hey pete check out the recent bubble window post,  ;)
Re: Steering column
« Reply #4 on: July 29, 2011, 07:43:00 PM »
Any one gets in this predicament for a Beddy steering warn bearing,replacement..u cant get them unless u buy the entire rack n pinnion,BUT we found a close match bearing alone,not cheap at $70ea and 2mm higher so u have to make a spacer for it,well thats wot my bro did,now it fist perfect & does the job great,yay!
Buy from:
RHP bearings- in Melbourne
Style code: LJT5/8Mb         RR 5
Barcode numbers on back of box are-747023  004478
Made in England
Re: Steering column
« Reply #5 on: July 30, 2011, 05:25:00 AM »
He's after bearings for the steering 'column' not the steering 'rack'.
Offline Sweet Shock
Re: Steering column
« Reply #6 on: July 30, 2011, 12:48:32 PM »
Yea there nylon bushes right ?
Offline Sweet Shock
Re: Steering column
« Reply #7 on: July 30, 2011, 12:52:51 PM »
Ive been told you can get them made up for about $ 70 at a engineer shop here. But I still have to check
Offline Worby876
    • UCB Australia
Re: Steering column
« Reply #8 on: July 30, 2011, 10:20:28 PM »
My steering wheel jutters when I'm doing 80 km/h or more down the motorway
Between brassy & the gold coast so it's not because of bad roads.
I'm guessing this could be from a worn steering column bush or bearing.
Is that the same symptoms you get ?
I know I need a new ball joint bush on the passenger side front end
I tried to check out Bedford manor but his website is gone does anyone
Know if he is still trading spart parts for bedfords?
Offline Sweet Shock
Re: Steering column
« Reply #9 on: July 31, 2011, 12:40:54 AM »
my symptons are steering not comon back quik enough and slight tight steering, It was steering better before I changed the rack.
