  • Dot Guests: 365
Author Topic: lose the window grooves with this advice from busy  (Read 8622 times)
Re: lose the window grooves with this advice from busy
« Reply #10 on: September 03, 2008, 07:44:43 PM »
haha
just then i read it and it didnt make sense what i wrote but i read it again and it made sense..
ummm
is it possible to use the existing recess that is standard on weld new panels onto? obviosuly youd have to pack them out so they are flush with the rest of it cause the recess is too deep..
« Reply #11 on: September 03, 2008, 07:58:28 PM »
Is it possible - yes
Is it easier - no
Is it harder - YES
There is no way to hammer weld or adjust the panel once you start welding, the only real way is to cut the grooves out.
I remember trying to do a similar method (using the groove) when I was a teen, folded the edge of the panels like _|------|_ (kind of thing), but back then it was the arc welder - not recommend
For the drivers side (even the pass if there is no side door) you can do it in one long panel, cut the centre section out and weld a little strip to the inner pillars, drill some holes in the outer panel and spot weld through these in the middle section. Saves a lot of welding but the panel is bigger and more awkward with more chance of warping it.
« Reply #12 on: September 03, 2008, 08:07:06 PM »
oh yeh i like that method.. cause then whhen people look for the seam it looks perfect!! ofcouse they dont know you didnt weld there lol..
thats if ive understood you right.. but sounds good..
